whats your fuel pressure at?
just wondering what every ones fuel pressure is at w/ a 255 fuel pump
pretty much stock internals? i had trouble at 60 psi i could not get down past 50
psi. whats a good setting for say around? 7 pounds of boost?
SOME ONE TOLD ME 50 PSI WAS OK? TRUE OR NOT?
the thing is i'm driving to califorina, and need to consume gas. so would i be ok
around 40-45 psi for the trip. give me some light. this fuel delivery is kicking my *** and my wallet?
thanks,
Ryan
thanks,
Ryan
I couldnt get my fuel pressure lower than 50psi with the b&m regulator, but i guess you get what you pay for. I took the walbro out for now and currently running stock pump at around 40psi. Gonna keep the walbro out until i get a better fpr to lower the static pressure.
btw, it depends on the size injectors your running. People usually put there static pressure up higher when their injectors are almost maxxed out.
i would like to take my pump out, but i had to drop the tank(accords lick *****)
so i guess i halft to drill a bigger hole in my diafram, to relese pressure.
i'm on stock injectors,boosting pretty much a stock motor.
TurboSpoolinInside
Jul 24, 2011 06:06 PM
