ouvalve adjustment on a SOHC vtec
i got a stupid question, ok i complete and udderly forgot how to adjust the valves on my sohc vtec motor, i dont know when it is at TDC i havent done it is so long but all i need to know is how to find that out and the clearences on a y8 cause it is tapping pretty bad so if anyone knows let me know thanks
[Modified by crxhfpower123, 4:44 AM 2/11/2003]
TDC is when cyl 1 is at TDC on the compression stroke
all marks should line up and cyl 1 @tdc and dizzy rotor at 1
for valve adjustment
start on cyl 1 @TDC
adjust intake lash to .007-.009
adjust exhaust lash to .009-.011
turn crank counterclock wise till you hit TDC on cyl 3
samd valve adjustment start with intake then exhaust
then do cyl 4
then do cyl 2
process complete!
to find the TDC of each cyl remove spark plugs and stick something long down there and watch it as you turn the crank (chopstick works nicely
_
[Modified by VTeC4TheChildren, 4:55 AM 2/11/2003]
start on cyl 1 @TDC
then do cyl 4
then do cyl 2
process complete!
_[Modified by VTeC4TheChildren, 4:55 AM 2/11/2003]
jdm_racer831
Apr 4, 2007 08:49 PM
