quick qiestion on exhuasts...
Old Feb 10, 2003 | 07:08 PM
sslude's Avatar
Default quick qiestion on exhuasts...
can you name the oder it goes it? like header then ect. ect.? tahnks and what is a b-pipe? tahnks
Old Feb 11, 2003 | 05:16 AM
JimBlake's Avatar
Default Re: quick qiestion on exhuasts... (sslude)
1 - exhaust manifold is bolted onto the head.
2 - head-pipe, or Honda usually calls this the "A" pipe.
(a tube header replaces the combination of #1 & #2)
3 - catalytic converter
4 - middle pipe, including middle muffler, Honda usually calls this the "B" pipe. It extends to near the rear axle.
5 - rear pipe, rear muffler, Honda usually calls this the "C" pipe?
Old Feb 11, 2003 | 02:37 PM
sslude's Avatar
Default Re: quick qiestion on exhuasts... (JimBlake)
i dont get #2, do you have some kind of picture? so the b-pipe is the mid section, in between the cat and the axleback portion? thanks
Old Feb 11, 2003 | 05:26 PM
jeddy0120's Avatar
yes the b pipe is in between the cat and muffler. the resonator is located in that portion.
Old Feb 12, 2003 | 05:14 AM
JimBlake's Avatar
#2 is the A-pipe, it bolts to the manifold, runs under the oilpan, & bolts to the front of the cat. If you buy a 2-piece header, like DC, the 2 pieces will replace the manifold & the A-pipe. If you buy a 1-piece header it still replaces both parts, but now they're not separate.
The B-pipe runs from the back of the cat (just about under the shift lever), to a point next to the RR wheel. A "cat-back" system includes the B-pipe & the rear section. An axle-back system just includes the rear sections.
riceburner6
Dec 6, 2007 10:28 AM
honda95civic
Welding / Fabrication
Aug 28, 2005 05:31 PM
9deuce9rr
Nov 8, 2004 06:13 PM
Nader_D
10
Nov 19, 2003 10:02 AM
01PYTypeR#1140
Sep 20, 2001 07:23 PM
