Is it true?
Old Sep 20, 2001 | 06:36 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default Is it true?
I heard I needed a piece of flex pipe between the Jdm header and highflow cat, because of front wheel drive. Wont this affect the flow of my excaust? DC sport Jdm header, carsound 2.5" cat, 2.5" straight pipe to stock muffler is what I'm working on geting done. Can someone confirm this flex pipe business, or is there another way?
Old Sep 20, 2001 | 06:42 PM
Chris's Avatar
Default Re: Is it true? (01PYTypeR#1140)
There is a donut gasket in there that allows flex.
Who told you that? A person that has NO expirence with FWD???
BTW, dont forget to change out the Muffler bearings after you install the flex pipe.
Old Sep 20, 2001 | 06:43 PM
Chris's Avatar
And then why isnt there one on any stock cars???? :bigfukinhammer:
BTW this is not a flame to you....just your scource.
Old Sep 20, 2001 | 07:16 PM
Default Re: Is it true? (Chris)
If I were to use a piece of 2.5" flex pipe would it be O.K. or would it hurt the flow of my excaust?
Old Sep 20, 2001 | 07:23 PM
SamB's Avatar
New User
You don't need to put the flex in as the joint between the header and cat allows for movement of the engine (thats why its spring loaded - so it can move). Flex pipe is used by manufactures who don't use the dounut system.
If you really want to put flex pipe in make sure that is 2.5" ID and be aware that they are not smooth inside which may affect flow. HTH
Sam
jdmsohc2nr
Jan 1, 2008 08:40 PM
blykins
Feb 22, 2004 12:47 PM
uncleben
Jun 21, 2002 08:19 PM
eTec
Apr 16, 2002 01:11 PM
