What forged pistons have the least piston to cyl. wall clearance? or they all the same?
Old Feb 10, 2003 | 06:33 PM
sporkcrx's Avatar
Default What forged pistons have the least piston to cyl. wall clearance? or they all the same?
I'm planning on using forged pistons in my daily driver, n/a w/ the occasional nitrous. And I'm wondering if there's a brand that usually has a tighter clearance than all the others so everytime i start up my car (like a dozen times a day) it's not slapping all over the place.
Old Feb 10, 2003 | 08:51 PM
sgT's Avatar
sgT
Default Re: What forged pistons have the least piston to cyl. wall clearance? or they all the same? (sporkc
Toda.
Thatsit.
Old Feb 10, 2003 | 10:22 PM
TimoneX's Avatar
New User
Pistons with high silicon content expand less than pistons with low silicon content and as such can have very tight cylinder wall clearance. The highest silicon content I'm aware of is in OEM Honda pistons. Aftermarket forged pistons tend to have somewhat less, but Wiseco & JE/SRP, have a higher silicon content than Ross & Arias and as such are able to manufacture pistons with tighter cylinder wall clearances.
I've no idea what silicon content Toda pistons have, but if Sgt says they have tight cylinder wall clearances I suspect they're a high silicon content piston.
Old Feb 11, 2003 | 09:31 AM
sporkcrx's Avatar
Awesome! I was planning on using SRP's or Wiseco's anyway (seem to be the least expensive). Thanks for the help!
Old Feb 11, 2003 | 10:59 AM
CHEETAH's Avatar
actually Arias are way high on the list ...
very low on the list are Toda and Ross .. and new Endy Kukta
in the middle are the Endyn lines made by Wiseco ...
Greg
Old Feb 12, 2003 | 10:09 AM
sporkcrx's Avatar
So Arias are up on top of the list...are Wiseco's still?
Old Feb 12, 2003 | 10:54 AM
sgT's Avatar
sgT
when he says top, he means needing the most clearance
Old Feb 12, 2003 | 10:59 AM
TimoneX's Avatar
New User
All the info I've seen on Arias pistons indicates they're low silicon and therefore expand more than other manufacturers pistons(Wiseco, JE/SRP). I think if you do a search on Arias pistons you'll likely find several people commenting on the noise they make when cold. Certainly tolerable, but something to be aware of.
Old Feb 12, 2003 | 11:00 AM
sporkcrx's Avatar
Oh ok, thanks for clearing that up. So srp or wiseco's are a good choice then eh.
Old Feb 12, 2003 | 11:01 AM
sporkcrx's Avatar
I don't give two ***** about noise...but I don't want them to beat the hell out of themselves and the walls everytime I start her up.
Old Feb 12, 2003 | 11:20 AM
sgT's Avatar
sgT
the more hp you make, the more clearance you will need with a forged piston.
something to keep in mind
Old Feb 12, 2003 | 11:31 AM
sporkcrx's Avatar
****, it wont be much, d16a6, maybe like 150-160whp...then the occasional 80 shot.
Old Feb 13, 2003 | 11:53 PM
aeolus's Avatar
the clearance specs are not the only reason why the pistons are so loud.I dont know if anyone has really noticed this,but stock honda pistons dont have the wrist pin hole right in the middle of the piston.Usually it will be offset to one side to prevent the piston from rocking around so much.If you do a search on it on the web,youll see that this has been done for a while already to make engines run a little quieter.Arias pistons i know for a fact do not have offset wrist pins.
xDicktonesx
Jun 14, 2006 08:24 PM
PrecisionH23a
Mar 17, 2005 06:12 PM
aznpreludeSH
Feb 20, 2005 09:38 AM
ArinX
Honda S2000
Oct 23, 2004 07:40 PM
95c1v1cs1
Jul 28, 2004 09:44 AM
