Wheel and Tire Combo
Old Feb 10, 2003 | 01:07 PM
BlazinITR's Avatar
New User
Default Wheel and Tire Combo
Need feedback from people who's rollin on 17's!
Want to know if I would have any rubbing problem with 17" rims with 43 offset and 215/40/17 tires?
Thanks!
Old Feb 10, 2003 | 01:29 PM
TimoneX's Avatar
New User
Default Re: Wheel and Tire Combo (Blazin ITR)
I don't have any rubbing w/ 17x7 42mm offset wheels and 205/40-17s on my GSR. You're talking 2-3mm more tire inside the wheel well, so I'd think you'll be fine depending on ride height.
Old Feb 10, 2003 | 01:37 PM
yoshi234's Avatar
I shoot brides
with +43 and 215's, it's gonna be pretty close
i barely rub in the rear w/ +40 and 205/45 (A520s) but don't rub w/ 205/40(T1-S)
Old Feb 10, 2003 | 02:23 PM
BlazinITR's Avatar
New User
Default Re: Wheel and Tire Combo (TimoneX)
From TireRack.com Calucalating Tire Info:
The first number is the width of the tire in millimeters, measured from sidewall to sidewall. To convert to inches, divide by 25.4 In the example above, the width is 185mm or 7.28".
The second number is the aspect ratio. This is a ratio of sidewall height to width. In the example above, the tire is 7.28" wide, multiply that by the aspect ratio to find the height of one sidewall. In this case, 185x0.60=111mm or 7.28"x0.60=4.36".
The last number is the diameter of the wheel in inches.
To figure the outside diameter of a tire, take the sidewall height and multiply by 2,(remember that the diameter is made up of 2 sidewalls, the one above the wheel, and the one below the wheel) and add the diameter of the wheel to get your answer.
Example...185/60R14 85H or 185/60HR14
185mm x .60=111mm x 2=222mm + 355.6mm(14")= 577.6mm or 22.74"
Stock ITR rims:
195/55/15
195*.55=107.25mm*2=214.5mm+381mm(15")=595.5mm or 23.44"
New Volk rims:
215*.40=86mm*2=172mm+431.8mm(17")=603.8 or 23.77"
Difference of 8.3mm or .33"
[Modified by Blazin ITR, 3:34 PM 2/10/2003]
Old Feb 10, 2003 | 02:55 PM
BlazinITR's Avatar
New User
Default Re: Wheel and Tire Combo (yoshi234)
Yoshi,
Is your Kaa dropped?
Old Feb 10, 2003 | 03:01 PM
yoshi234's Avatar
I shoot brides
Yoshi,
yes, 3/4~1"
Old Feb 10, 2003 | 03:03 PM
B16A2-EM1's Avatar
I run 17x7 Enkei RF-1z no rubs until I installed Camber kit, now I have to get my rear wheel wells rolled so I can lower more.
Old Feb 10, 2003 | 06:55 PM
Leo's Avatar
Leo
Default Re: Wheel and Tire Combo (py1091)
Dumb question. If the offset goes from 50 to 42, does that mean the wheel sits further in or out of the wheel well. Thanks.
^AnDre^
May 1, 2007 06:39 AM
honda95civic
Mar 27, 2005 08:10 PM
Quick4
Apr 22, 2004 02:28 PM
Mr. Vapor
Jul 1, 2002 11:23 AM
X2BOARD
Oct 7, 2001 09:34 PM
