Anyone here put on springs with air tools?
Old Feb 10, 2003 | 11:16 AM
pogichinkyguy's Avatar
Default Anyone here put on springs with air tools?
Just wondering how much harder/longer it would take without air tools...
Old Feb 10, 2003 | 11:27 AM
bikeboy80's Avatar
Default Re: Anyone here put on springs with air tools? (pogi*****yguy)
air tools can make the job go a bit faster, but unless you have real expensive tools you will still have to break the bolts loose and tighen then down with a breaker bar/ or wrench.
The first two time i did my suspension i did not have air tools and it took me a few hours (i was still learning) no i have air tools and i can swap out the suspension in maybe an hour if all goes well
but air tools are not a nessacity
Old Feb 10, 2003 | 11:31 AM
Vspec Sol's Avatar
It's not a necessity, the only thing that I really find convinient is to have a lift, but everything can be done without air tools.
Old Feb 10, 2003 | 11:37 AM
kommon_sense's Avatar
Default Re: Anyone here put on springs with air tools? (Vspec Sol)
i used air tools and it made it easier. It took a few hours because it was my first time doin suspension work. I did not have any stiff/frozen/rusted/stuck bolts at all (car is a 98 civ, did suspension Sept. 02).
Old Feb 10, 2003 | 11:53 AM
SlippylesKB's Avatar
Default Re: Anyone here put on springs with air tools? (kommon_sense)
If you have an older car, I wouldn't recommend using Airtools. Just a breaker bar is the way to go. I had airtools available to me, but I decided to use regular wrench's because you get a better feel of when your about to break a bolt (check out my post ) All you need is a little muscle and your good friend named leverage. Good Luck
Scott
Old Feb 10, 2003 | 12:35 PM
Default Re: Anyone here put on springs with air tools? (SlippylesKB)
Thanks guys, I'll let you the out come...
Old Feb 10, 2003 | 12:38 PM
smnowell's Avatar
I think air tools really only help on the rear suspension. I can do front suspension with hand tools (both sides) in about 20-30 minutes. Only reason rear is harder is because those ******* bolts seize in the lower strut mount onto the control arm...sometimes even air tools can't get those bolts out...But basically, hand tools should be more than enough for you. Maybe a long pipe to use as a breaker bar for some of the harder bolts and you will be set
Old Feb 10, 2003 | 02:16 PM
Default Re: Anyone here put on springs with air tools? (b16a ferio)
Yea the equation would go something like this:
Airtools + Rusty Bolt = Pissed off Scott, stock height rear and 2 broken bolts...
Like I said, I'd advise against using Air tools
DEBTsE-at
Aug 9, 2012 11:35 AM
Civic_07
20
Dec 4, 2008 02:17 PM
pjr710
Suspension & Brakes
17
Jul 9, 2007 08:15 PM
CXHatchback
Oct 11, 2002 07:13 PM
Chicotrini
May 15, 2002 05:47 PM
