Tranny fluid fill location.
Old Feb 10, 2003 | 07:01 AM
migs's Avatar
Default Tranny fluid fill location.
I know the standard fill location for the tranny is mounted sideways. I was wondering if it can be filled uptop by removing the VSS?
tia
migs
Old Feb 10, 2003 | 07:07 AM
Dave-ROR's Avatar
Default Re: Tranny fluid fill location. (Migs)
tia
migs
yes.
hungsteR's Avatar
VSS = Vehicle Speed Sensor? If so then yes. Check here Migs.
Old Feb 10, 2003 | 08:07 AM
baonest1's Avatar
Default Re: Tranny fluid fill location. (hungsteR)
yup.... i just did mine about 3 days ago through the VSS... make sure the car is level. and stick a funnel down there.. its about 2.6 qts or so.
[Modified by baonest, 12:08 PM 2/10/2003]
Old Feb 10, 2003 | 08:14 AM
PhucNguyen57's Avatar
Default Re: Tranny fluid fill location. (baonest)
https://honda-tech.com/zerothread?id=408411
Old Feb 10, 2003 | 09:01 AM
migs's Avatar
Default Re: Tranny fluid fill location. (PhucNguyen57)
2.4 QTs Dry
2.2 QTs Normal
Old Feb 10, 2003 | 09:57 AM
baonest1's Avatar
welli poured a bit more to make sure it was pouring out of the hole... 2.4 is what it says in the helms..
Old Feb 10, 2003 | 10:01 AM
Nameless RB26's Avatar
Alot of people fill where the VSS is.
Just unbolt the farthest bolt and pull the whole thing out..
luv2boost
Aug 8, 2007 08:10 PM
93sihatchy
May 22, 2007 05:14 AM
nfinitecc
Dec 3, 2004 03:47 PM
dxhatch92
Mar 23, 2004 11:29 AM
gotnothing
Jan 26, 2003 07:42 PM
