oem front lip install
Old Feb 10, 2003 | 04:39 AM
2000GSR's Avatar
Default oem front lip install
Did a search and came up with nothing. Anybody have printed instructions on how to put it on? Seems easy enough but I want to make sure I put it on properly. Thanks.
Old Feb 10, 2003 | 04:49 AM
tC_Dragon's Avatar
Default Re: oem front lip install (2000GSR)
damn i think i've answered this question a milliontimes.. haha.. but here goes...
GO TO THE DEALER AND ASK FOR A PRINT OUT.
ok... now that we covered what you should have done... i'll stop being a jackass and help ya out. haha..
-There should have been some metal clips with nuts welded to them, those clip onto preexisting slots on teh bottom of your front bumper, when you line up the lip to the bumper, and look underneathe, you'll see where i'm talkin about. Slide those clips in, then bolt up the lip thru those nuts.
-hold up the lip to the front bumper in the position it should be mounted in, and if you look in the fender area, you see there are two holes in the lip, one that goes thru an existin hole in that area, and one that doesn't have a hole. Use the included self-tapping screw to make a new hole and mount it.
-Once you have these in, then you can look underneath the lip, where you will see a metal mounting bracket (one on either side) with a small hole/slit on it, drill a hole in this position and mount with the supplied hardware.
I thinkthat about covers it. Hope that helps buddy.
Old Feb 10, 2003 | 06:32 AM
2000GSR's Avatar
Default Re: oem front lip install (pdcdragon)
thanks for the info! i appreciate it.
Old Feb 21, 2003 | 11:15 AM
Hairy Gorilla's Avatar
anyone know the part numbers for allthe bolts and everything? I just bought a ITR lip and it had zero nuts or bolts or anything. Thanks
Old Feb 21, 2003 | 02:05 PM
Superesc's Avatar
Default Re: oem front lip install (TimmyMaryak)
if you really can't figure it out, you can do what I "did", bolt on the 2 bolts in the wheel well, and use Heavy duty Velco around. As funny as this sound, it work semi well. it won't come off, but it might not look as low as it can be. Also it can scratch your bumper...
Old Feb 21, 2003 | 02:11 PM
dfoxengr's Avatar
LOL..theres little hole things if u look at the bottom of the bumper where it goes, my friend did his in 15 minutes, haha....
Old Feb 21, 2003 | 02:17 PM
B00ST2nR's Avatar
Default Re: oem front lip install (hybridvteceg)
VERY Easy. I install my whole kit in 45 minutes.
10 minutes for the Front Lip
10 minutes for the Side Skirts
25 minutes for the Rear Dress
It's pretty self-explanatory if you look under your car and the Lip.
Old Feb 21, 2003 | 02:57 PM
beaterman's Avatar
**** all i put on was the two stock bolts in the wheel well. and mine is sitting fine. but im going to put the other bolts on eventually i just dont have a jack right now to get my car up.
Old Feb 21, 2003 | 06:47 PM
Default Re: oem front lip install (beaterman)
That is all I have on right now too, and it seems to be doing alright, but I definately want to put at least 2 more in on the bottom. I really LOVE the look of my car w/ the lip installed!
Old Mar 19, 2003 | 07:23 AM
iwantfastcars's Avatar
Default Re: oem front lip install (Tim Maryak)
i used bolts and washers for mine....
cor4ey
Feb 8, 2010 05:08 PM
rawNArsxS
May 8, 2008 02:17 PM
handa
Feb 24, 2005 01:51 PM
OneFire
Oct 5, 2004 09:37 PM
integranator
Dec 9, 2002 06:47 AM
