New Ground Kits Show Added HP
Old Feb 10, 2003 | 01:10 AM
ranta18's Avatar
Default New Ground Kits Show Added HP
What are your guy's comments on the new Hyper Ground System ground kits? I've seen them dyno tested in last month's Turbo magazine and in some other magazines and have shown to make hp at almost every rpm range, and even up to 10 hp and 10 ft/lbs at points. Dyno graphs can't lie I guess. Do you think there are any advantages of those over some 4 ga copper high quality speaker wire? Do you think that they are worth the $120 or so, or would you do it yourself?
Old Feb 10, 2003 | 03:17 AM
SoulSurfer's Avatar
Default Re: New Ground Kits Show Added HP (ranta18)
Dynos can't lie but I wouldn't put it past someone to adjust the timing or something to gain a little more power after they put their product on.
Old Feb 10, 2003 | 09:32 AM
advanracing62's Avatar
Default Re: New Ground Kits Show Added HP (LSDelSol)
I have a friend that bought a kit, I went to the stereo shop and got some 4awg ground cable and some connectors. I made my cable kit and installed it. Then I installed his kit. There was no change from mine to his as far as HP and TQ were concerned. His was a little flashier.... HTH
Old Feb 10, 2003 | 09:40 AM
1BlackHatch's Avatar
Can someone explain to me theoretically why this is supposed to gain HP?
Old Feb 10, 2003 | 11:15 AM
ScottEK's Avatar
Default Re: New Ground Kits Show Added HP (1BlackHatch)
Theoreticlly, less interferance on all your sensors, stronger electrical system.
Have you ever had a bad spark plug or forgot to hook up a grounding wire.
Rockale
11
Oct 5, 2014 08:11 AM
951dc5
24
Jun 7, 2007 11:36 PM
EGY8
Feb 15, 2007 08:06 PM
SublimeStyles
Sep 27, 2003 10:21 AM
RaVAGE00
Mar 4, 2003 01:35 PM
