70mm t/b too big for n/a motor??
Old Feb 9, 2003 | 10:58 PM
JDMvtecDRAGSTA's Avatar
Default 70mm t/b too big for n/a motor??
i got one of those rpm 70mm throttle bodies with a port matched itr manifold.
i hear stuff from people saying that the 70mm is too big...
whats your thoughts on this
is 70mm too big???
thanks
Old Feb 9, 2003 | 11:06 PM
BlackDeuceCoupe's Avatar
HT White Ops
Default Re: 70mm t/b too big for n/a motor?? (Mr. Sparkle)
You bought it. Why don't you tell us???
Old Feb 9, 2003 | 11:08 PM
Nameless RB26's Avatar
Default Re: 70mm t/b too big for n/a motor?? (BlackDeuceCoupe)
tune it and tell us...
I bet it's fine.
Old Feb 9, 2003 | 11:38 PM
Default Re: 70mm t/b too big for n/a motor?? (Nameless)
i didnt buy it i got it for free from a friend.
so why not just answer the question
Old Feb 9, 2003 | 11:41 PM
STEALTHMODECOUPE's Avatar
i dont see a problem with it..a bigger T/B w/ a port matched intake mani is a good mod if you ask me..now just get the head ported..
adaM
Old Feb 9, 2003 | 11:44 PM
Default Re: 70mm t/b too big for n/a motor?? (STEALTHMODECOUPE)
yah the head is not pp yet, and im running on some jun3s
i still need a b18 block and pp head.
gg
Old Feb 10, 2003 | 12:56 AM
JDMb18civic's Avatar
im using a 70mm TB...
no prob with my 200whp NA motor
Old Feb 10, 2003 | 04:59 AM
wHOAlly's Avatar
Default Re: 70mm t/b too big for n/a motor?? (JDMb18civic)
too big? no way
Old Feb 10, 2003 | 12:27 PM
Default Re: 70mm t/b too big for n/a motor?? (There is no sp00n!)
thank you for your responses
a to you
gg kthx
Old Feb 10, 2003 | 12:45 PM
euclid's Avatar
i am under the impression that a 70mm is too big straight through, that hp will actually decrease throughout the powerband and it needs to be tapered to see good throttle response, but i think that is refering to a stock intake manifold. since yours is matched i would think that you will get better top end and peak hp #'s but loose alittle off the line and in the low end. but i could be wrong.
i realize that you didnt pay for it, but do you know where this work was done and how much it all cost?
and your avatar is awesome!
bikeboy80's Avatar
you will probally lose low end with a tb that big, don't know if that matters to you or not
Old Feb 10, 2003 | 03:04 PM
wHOAlly's Avatar
Default Re: 70mm t/b too big for n/a motor?? (bikeboy80)
have u EVER seen a dyno sheet of a high output motor with JUST a TB upgrade? gains EVERYWHERE.
hell even a stock motor with a 64mm TB upgrade u will see gaines everywhere...
Old Feb 10, 2003 | 03:07 PM
Scotty B's Avatar
is 70mm too big???
It depends on what motor, and the state of tune it is in..... if you are moving alot of air through the motor you will be just fine......
thanks
Old Feb 10, 2003 | 03:11 PM
euclid's Avatar
no, actually i havnt but i would love to see one... can you help me realize this dream?
Old Feb 10, 2003 | 03:30 PM
AllMotorMark's Avatar
Default Re: 70mm t/b too big for n/a motor?? (euclid)
i will post my before and after i only have the after right now but i will go back to the dyno to get the before dyno, I made 5-10hp from 3000 rpm to 8500 rpm and about 5-10 ft/lbs also. I upgraded from a 65mm tb to a BBK 70mm and i made a huge difference.
Old Feb 10, 2003 | 04:45 PM
Bumnah's Avatar
Default Re: 70mm t/b too big for n/a motor?? (T.O.STREETRACER)
I have an ericks racing 70mm tapered to 68 mm tb. I just port matched it to my skunk2 manifold on saturday. I'm thinking it's gonna be fine cause the difference wasn't as big as I thought it would be. I think you'll be fine.
Btw, the port match only cost me $20 bottle of liquor. Helps to have friend who are machinists
Old Feb 10, 2003 | 05:44 PM
bikeboy80's Avatar
Default Re: 70mm t/b too big for n/a motor?? (Bumnah)
ok, calm down guys. you are right i have never seen a car lose power from a 70mm tb, but i also have not see one gain in person.
i guess this is wrong but i understood that going with a large tb like that affects the motor the same way that heavily porting the head out, that the engine would gain high end hp but actually lose tq down low, or am i wrong about that too
i am still learning just as i bet all of you are and im sure all of us make mistakes, sorry
Old Feb 10, 2003 | 05:47 PM
-Whitey-'s Avatar
its personal preferance..alot of people like 70mm or bigger and alot of people stay a little under 70mm..i am one that stays under 70mm because its not the size its how you use it
Old Feb 11, 2003 | 07:21 AM
euclid's Avatar
im not trying to start **** but dont get defensive about your position untill he either posts a dyno showing gains throughout or "EVERYWHERE" in the powerband or someone else respomds who has dropped a 70mm tb onto a stock intake manifold... i have no doubts that peak hp will increase with this guys portmatched setup but i still think he will loose low end. and i am pretty sure a bigger tb will not gain ANYWHERE on a stock intake mani on an NA engine, plus you will lose throttle response if it is not tapered. i cant wait to see a 5-10hp/tq increase on a dyno from just a tb... i will be buying one tonight if that is the case, but i dont think it is.
Old Feb 11, 2003 | 07:54 AM
bikeboy80's Avatar
thanks, i miss read your quoted post and thought you were against me too, so its just the other guy
that's exactly my thoughts, that large of a tb on and other wise stock motor (except for cams) is just too big
if the plan is to do the im and head work in the future then fine keep the thing and you'll see gains all over when that work is done
Old Feb 11, 2003 | 11:14 AM
Scotty B's Avatar
you sjould be fine.....you will definetly need to get one that tapers to at least 68mm.
Old Feb 11, 2003 | 11:24 AM
Default Re: 70mm t/b too big for n/a motor?? (nasi)
lol thx
gg
brand_NOOBian
Mar 31, 2007 04:43 PM
Suck my DX
10
Mar 9, 2007 12:14 PM
Kyoto now
Nov 4, 2006 07:38 PM
sohctodohc
Sep 2, 2006 12:37 AM
buck02
Feb 3, 2004 04:40 PM
