again...skunk2 adjustable upper control arms.
Old Feb 9, 2003 | 07:29 PM
Phoenix_ITR's Avatar
Default again...skunk2 adjustable upper control arms.
i've already done a search and read pretty much every thread involving the Skunk2 pieces -- i came across pretty mixed reviews, to say the least.
i've already ordered the arms to be used in conjunction with my current spoon spring/stock shock setup. i came across a number of instances in which the arms slipped -- this does not seem to be that big of a deal to me, and i'm sure that i can correct it with minimal effort. however, i also came across problems involving both the balljoints as well as problems with the A-arm contacting the fenderwell. can anyone shed some light on either of these problem
also, will i have to modify the arm in any way in order to make it work well, and if so, how would i go about doing this? thanks for all your input.
-tony
Old Feb 9, 2003 | 10:35 PM
Default Re: again...skunk2 adjustable upper control arms. (delinquent)
nobody has any feedback/reviews about the UCA?
Old Feb 10, 2003 | 01:43 AM
Warren's Avatar
Wrong-Way Wang
If you swap left/right to gain caster, you will lose a little clearance. Check the ball joint boot often as it degrades quickly.
Warren
Old Feb 10, 2003 | 02:38 AM
Default Re: again...skunk2 adjustable upper control arms. (Warren)
Warren
what are the replacement options for when the ball joint does, in fact, crap out on me? thanks for your help!
-tony
Old Feb 10, 2003 | 03:16 AM
Asahi's Avatar
I tore a boot (my own fault) on my kit and called Skunk2 to inquire about getting a new boot. The guys says "ok, what's your address I will get one out today". No charge and arrived 3 days later.
They seem to be pretty easy to work with you might call Group-A/Skunk2
Old Feb 10, 2003 | 04:47 AM
rolow's Avatar
Default Re: again...skunk2 adjustable upper control arms. (Asahi)
I guess I am going to have to call because they have been ducking my emails adount new balljoints.
I had the clearance issue but fixed it with a little grinding of the hex head bolt
I also have had a problem with the ball joint boots. I have not fixed this yet.\
I have never had them slip. I do not autocross and am not very agresive on the street.
[Modified by rolow, 1:47 PM 2/10/2003]
Old Feb 10, 2003 | 05:18 AM
well that makes me feel better about my purchase! if you don't mind, could you PM me the number that you called, just so that i have it? i'd really appreciate it. also, as with most warranty issues, did they request that you ship the torn boot back to them? thanks again for all your help.
-tony
Old Feb 10, 2003 | 05:21 AM
PhucNguyen57's Avatar
this makes me want to stay away from them. I was going to get some in the next week or two. Not now.
Old Feb 10, 2003 | 05:24 AM
Default Re: again...skunk2 adjustable upper control arms. (PhucNguyen57)
after doing some research, i've determined that they're still pretty nice pieces -- they just have a few issues that you need to be aware of.
-tony
Old Feb 10, 2003 | 06:37 AM
migs's Avatar
I like the Skunk2 arms. They give me the camber adjustment I NEED.
I ordered my Skunk2 arms a few months ago, and after putting a small amount of mileage (mostly highway), the balljoint seperated AND the boot tore on both sides. I sent them back to Skunk2/Group A and they got me the new balljoints with no charge. I was happy.
The arms hit my chassis only because my car is WAY low. Probably lower than it should be.
Here is a thread that I made https://honda-tech.com/zerothread?id=281597
Very well put.
-tony
[Modified by Migs, 9:39 AM 2/10/2003]
Old Feb 10, 2003 | 06:42 AM
Asahi's Avatar
Default Re: again...skunk2 adjustable upper control arms. (Migs)
This is more commonly the case than any design flaw in the arms.
1993_EJ1
Jan 5, 2011 11:51 PM
jadugartir
Jan 6, 2008 12:16 PM
Hartlage
11
Jul 10, 2003 12:18 PM
Phoenix_ITR
14
Feb 10, 2003 01:55 PM
Phoenix_ITR
Feb 9, 2003 11:25 PM
