Removing engine
Old Feb 9, 2003 | 07:11 PM
tylerdurden's Avatar
Default Removing engine
Well, it looks like I'll be getting a new engine (rebuilt d-series), and I was wondering how long the removal generally takes (for a first timer with some help)?
I'll need to take out the old engine, take off the trans, take the trans to get rebuilt, then I'll have some time to do some other work to the car while that's being done.
Will I need to disassemble the suspension to get the engine out? I know I have the take the axles out of the trans (obviously), but will I have the suspension disassembled enough that it would be worth my while to work on my bushings?
Any random tips? Any of the reinstallation particularly tricky? How difficult is retensioning the main belt? Should I replace the alternator while the engine's out (it seems fine now)?
Old Feb 9, 2003 | 07:12 PM
ViperRedCRX's Avatar
Default Re: Removing engine (tylerdurden)
1st time, just swaping the same engine in day to a day and a half
Old Feb 9, 2003 | 07:13 PM
Toptul_Honda's Avatar
New User
well if u dont mind having your car off the road. do as much as possible in one shot (if u have the funds too)
Old Feb 9, 2003 | 07:21 PM
keithv's Avatar
Default Re: Removing engine (G2-Rex)
i just posted a how-to on pulling the motor out of the bottom of the car. i am having problems with the pics and will try to fix them in the morning.
https://honda-tech.com/zerothread?id=411175
Old Feb 9, 2003 | 07:45 PM
USDM 4G VTEC's Avatar
actually my first time it took me 2 hrs to take it out, bc i was by myself...
but isnt such a big deal
if u dont like the bottom engine removal like breaka,
just loose the wishbone thingy that holds the strut, the lower balljoint, and the knuckel will open like a books page.. that way u can take the axle out...
Default Re: Removing engine (breaka_1_9)
Nice writeup, I may go that way so I don't have to rent an engine hoist. You said the knuckles didn't have to be removed to get the engine out this way, but how would you have pulled the engine out if the hub assy was still in the wheelwell (pardon my ignorance). I understand that the whole assy swings away when the radius rods and axles are removed, but wouldn't it still kind of, you know, be in the way?
BTW, how hard is it to remove the front crossmember (please don't tell me the bumper needs to be removed)? Once the engine is resting on the holder, you must still have jackstand holding the car up for when the mounts are undone, yes?
[Modified by tylerdurden, 4:49 AM 2/10/2003]
Old Feb 10, 2003 | 03:24 AM
keithv's Avatar
i am gonna add your question to my other post, but i will reply here, too...
well i don't know for a fact that they don't need to be removed, since i have done it this way 2 times now and both cars had the knuckles missing. i think if you jack the car up a little bit higher, you can slip the motor out without any problems. the more i think about it, the more i realize that i pull the motor out under the front frame rail, so the knuckles wouldn't be in the way (i am pulling the motor out more towards the front).
you just need a breaker bar, a 17mm socket and that is it. the crossmember comes out without taking the bumper off.
actually i had a jack holding the car up. the car is so low that jackstands would keep the car too high. i used a 2x4 across the front tow hooks and a jack to keep the car up. i think a 4x4 would work better since the 2x4 flexed some, but you would need a very low profile jack...
quietjet
Honda CR-V & Element
Oct 18, 2022 08:40 PM
Bright13
May 27, 2016 01:36 AM
OTT
Feb 10, 2004 02:56 PM
