Need help on installing a Air/Fuel Ratio Gauge
Old Feb 9, 2003 | 05:30 PM
808_Spoon_EG's Avatar
Default Need help on installing a Air/Fuel Ratio Gauge
k well heres my problem....i bought a air/fuelratio gauge from a friend and it didnt come with instructions.....now im being honest with you....*i have no frickin cluehow to hook it up*..... ....so please help me.....pictures would be good.........and if it helps the installation is on a 92" EG dx...peace out and thanks again
[Modified by 808_Spoon_EG, 2:32 AM 2/10/2003]
Old Feb 9, 2003 | 05:34 PM
tominos's Avatar
Default Re: Need help on installing a Air/Fuel Ratio Gauge (808_Spoon_EG)
red goes to power, black to ground, purple to o2 sensor signal.
Old Feb 9, 2003 | 06:42 PM
civicracer1993's Avatar
Default Re: Need help on installing a Air/Fuel Ratio Gauge (tominos)
what if i tap into the O2 sensor wire in the engine bay would that work also? i dont know about this..
Old Feb 9, 2003 | 06:57 PM
1 2 NV's Avatar
alright, ive seen 4 threads on this in the last week alone. learn to use the search function. on top of that theres only 3 ****** WIRES. use ur ****** heads. jesus, if u cant figure out 3 wires then maybe u shouldnt b workin on ur car.
Old Feb 9, 2003 | 07:00 PM
MyVtec8u's Avatar
Default Re: Need help on installing a Air/Fuel Ratio Gauge (hondaatwsu)
shut up *******!!!
Take the red wire to a 12 volt power source of some type.
Take the black to a ground.
Take the purple or green wire to the o2 sensor on your headers or your cat!!
Good Luck!
Old Feb 9, 2003 | 07:19 PM
1 2 NV's Avatar
Default Re: Need help on installing a Air/Fuel Ratio Gauge (MyVtech8u)
myVtech8u.
comin from u i find this totally funny.
Good Luck!
yeah take the purple or green wire to the O2 sensor on your headers. once again i find this very funny.
Old Feb 9, 2003 | 07:27 PM
MyVtec8u's Avatar
myVtech8u.
Good Luck!
Workin on honda's isn't my life ****** i am just trying to help this person out!!
Old Feb 9, 2003 | 07:45 PM
1 2 NV's Avatar
ur right, u obviously dont work on hondas all day. ur a telecommunications guy. ill help u out a bit and direct u to here: http://www.vtech.com/about/history.htm
Old Feb 9, 2003 | 07:49 PM
976's Avatar
976
New User
Power I use it radio fuse.
Ground I use is bolt from ECU.
Then I tapped signal wire to D14 wire on ECU wiring harness.
BOO YEAH!
Old Feb 9, 2003 | 07:51 PM
tominos's Avatar
Default Re: Need help on installing a Air/Fuel Ratio Gauge (civicracer1993)
yes, how many wires is your o2, if it's one then tap into that, if it's 4 or whatever, you have to find the one with the signal. i don't remember off hand what color it is though.
Old Feb 9, 2003 | 11:45 PM
Vtec92Civic's Avatar
What a ******* dick! Maybe you shouldn't even be posting if all you're gona due is talk ****. How about you eat a fat dick and give the guy props for trying to hook this **** up. . . . . . you little byatch.
rainmanef
16
Jul 15, 2005 06:22 AM
lillthingz
Apr 17, 2005 07:05 PM
ZexyAccord
Nov 13, 2004 11:15 AM
