how to break in new cams in your car
Old Feb 9, 2003 | 11:06 AM
ravinR68's Avatar
Default how to break in new cams in your car
recently got some skunk2 stage 2 cams.....want to know how to break it in....like for how long to drive in low rpms..etc
Old Feb 9, 2003 | 11:22 AM
sgT's Avatar
sgT
Default Re: how to break in new cams in your car (ravinR68)
there isno break in necessary
Old Feb 9, 2003 | 11:36 AM
andrewasf77's Avatar
Default Re: how to break in new cams in your car (sgT)
really, i learn something new everyday from you guys
Old Feb 9, 2003 | 11:42 AM
AzG35's Avatar
I like to run the motor for 20 minutes at 2500 rpms after install. This allows the oil to circulate properly and lets the cams soak in some oil and gets the seats worked in. You don't have to do this, but many people do, especially with new valvetrain. Just try to use assembly lube on install.
Old Feb 9, 2003 | 12:40 PM
Willard's Avatar
Default Re: how to break in new cams in your car (AzSi22)
Old Feb 9, 2003 | 12:48 PM
integra_gsr98's Avatar
Default Re: how to break in new cams in your car (Willard)
With the cams that I've installed on DSMs and Hondas it's been very similar as to whats been posted up above. Make SURE to lube the cam journals well before you install the cam. Then torque to spec and re-assemble the head, reinstall the timing belt.
Then start the car and have someone hold it steady anywhere from 2500 to 3000 rpm for 25-30 minutes.
Old Feb 9, 2003 | 01:31 PM
ravinR68's Avatar
Default Re: how to break in new cams in your car (integra_gsr98)
ok......someone told me that u should drive the car for like 500 miles...without pushing the car...meanin keepin the rpm below 3 or 4k.....
Old Feb 9, 2003 | 02:23 PM
threatcon13's Avatar
New User
thats for a clutch.
Old Feb 9, 2003 | 04:38 PM
bryant's Avatar
Default Re: how to break in new cams in your car (Threatcon13)
There is no break in time for cams. Install and go.
Old Feb 9, 2003 | 04:39 PM
BlueR's Avatar
Default Re: how to break in new cams in your car (Bryant)
or install and dyno
Old Feb 9, 2003 | 08:25 PM
TypeR 01 886's Avatar
Default Re: how to break in new cams in your car (BlueR)
heh, when there is a break in period, what exactly is "break in" like does this mean, wear the engine to a certain point. I never quite understood it. I love technical explanations
Old Feb 9, 2003 | 08:44 PM
GSRfoedoe's Avatar
Default Re: how to break in new cams in your car (TypeR 01 886)
install adjust valves go race
Old Feb 9, 2003 | 09:06 PM
B2FiNiTY's Avatar
Hit vtak in reverse.
But seriously, no need to break them in. You can always do that for peice of mind but it really does nothing.
Old Feb 9, 2003 | 10:48 PM
sgT's Avatar
sgT
Default Re: how to break in new cams in your car (B2FiNiTY)
Just make sure you use JDM break-in oil
Old Feb 10, 2003 | 03:38 AM
J2turbo21's Avatar
Have you ever done that?I never seen reverse sound so cool except for the beep beep from big trucks.
Old Feb 10, 2003 | 04:27 AM
Christian's Avatar
Hey Steve,
I hope you brought some back from Japan for me? My local supplier has run out and I need some ASAP.
PS- The Proper break-in procedure is: 1) install cams and torque everything down to recommended specs 2) Check to make sure there are no extra parts a) if extra parts, tow car to your nearest mechanic b) if no extra parts, go to step three 3) start car and drive
lude98SH
16
May 16, 2008 07:25 PM
I got a honda
Oct 7, 2005 09:47 AM
ALLMTRGSR
Sep 27, 2002 01:33 PM
1.8Tities
Sep 25, 2002 04:47 PM
arw321
Sep 13, 2002 04:38 PM
