B16 Potential
Old Feb 8, 2003 | 10:38 PM
CandyRedHatch's Avatar
Default B16 Potential
Hey, my friend and I have been arguing a lot lately about the potential of a N/A B16, and I was seeing if anyone had any opinions on it. He says it is simply impossible to get a B16 to 240 hp at the wheels N/A without stroking the block. I say if that team with the crx with a N/A SOHC non vtec engine can run 10's, then a B16 can get to 240 hp N/A. So what do you guys think, or any of you have any proof for either way? Thanks.
Old Feb 8, 2003 | 10:59 PM
SlowPoke's Avatar
New User
Default Re: B16 Potential (CandyRedHatch)
well, its already hard enough for the b16 to hit 200whp all motor non stroked. I am gonna go out on a limb and say that its pretty much not gonnaa happen with the 240whp. Hardcore modded b18c's hit 210-220, so b16 isnt gonna cut it. Sorry as much as I love the b16's they just cant do that much hp in stock bore and stroke.
Old Feb 10, 2003 | 11:28 PM
BeavisB16's Avatar
The only thing i can think of is a gsr, ls, or b20 block under that head. b16 n/a as is would be good for 220 heavily modded (streetable), if this is a track car up the compression to run on race gas and some S2S3 camshafts.
[Modified by b16Civic93EXsleeper, 8:29 AM 2/11/2003]
Old Feb 11, 2003 | 06:36 AM
TimoneX's Avatar
New User
Default Re: B16 Potential (b16Civic93EXsleeper)
240whp is probably not realistic. Put in a b17 crank & rods, sleeve it to 86mm, raise compression to 12.5:1, add some agressive bump sticks, and tune it properly and you can probably shock allot of people that think the b16 is a toy, but I suspect you'd top out around 210-220ish.
matty413
Mar 10, 2006 07:49 AM
E dwinbon G
Jan 9, 2003 10:02 AM
JDMSI
Jan 5, 2003 10:15 PM
blazin
Aug 27, 2002 08:13 PM
