Tach not working. How do you test for signal?
Old Feb 8, 2003 | 05:10 PM
Steve91's Avatar
Default Tach not working. How do you test for signal?
This is on a 91 SI. It worked until today, then stopped. Anyone have a link to the electrical troubleshooting manual online?
Old Feb 8, 2003 | 11:15 PM
smokey2.0's Avatar
Default Re: Tach not working. How do you test for signal? (Steve91)
check that the blue wire, on the distributor plug is not broken. i just found mine broken, after i noticed that my tach wasn't working! If that's not your problem, trace that same wire back to the instrument cluster. check for continuity in that wire, from the cluster to the distributor.
Old Feb 9, 2003 | 09:18 AM
Camshaft's Avatar
Your stock tack isn't working ?
Your options are swap a good cluster in see if it works.
When you do that you can check the Ohms on the blue wire to the distributor
I rememeber having intermediate problem once and it was a loose wire inside the distributor
good luck
[Modified by Camshaft, 6:33 PM 2/10/2003]
Old Feb 10, 2003 | 07:39 AM
Steve91's Avatar
Default Re: Tach not working. How do you test for signal? (Camshaft)
Yeah, the stock tach just stopped working Saturday. Should there be any resistance on the blue wire or do I just check for continuity?
Old Feb 10, 2003 | 07:46 AM
keithv's Avatar
steve, you should see the voltage reading increase as you rev the motor.
DeeJaaY209
Sep 19, 2013 01:27 AM
johnwohl
Jan 20, 2008 02:41 PM
Firefoxracer
Nov 22, 2006 01:32 PM
b20guy
Apr 11, 2003 05:12 PM
civicracer1993
Sep 17, 2002 10:53 PM
