B18c5 lost motion assym. ?
Old Feb 8, 2003 | 12:25 PM
Kermit EK's Avatar
Default B18c5 lost motion assym. ?
are all Bseries vtec the same? And does anyone have the part number? thanks!
Old Feb 8, 2003 | 12:34 PM
D's Avatar
D
Default Re: B18c5 lost motion assym. ? (Kermit EK)
ITR LMA's are different.
Old Feb 8, 2003 | 12:38 PM
ZygSpeed's Avatar
D's right, the ITR LMA's are different.
You can probably look up the part numbers here:
http://www.acuraautomotiveparts.org/...ER+ARM+%282%29
[Modified by zygspeed, 4:41 PM 2/8/2003]
Old Feb 8, 2003 | 12:42 PM
D's Avatar
D
Default Re: B18c5 lost motion assym. ? (zygspeed)
Acura automotive doesn't list part numbers.
Old Feb 8, 2003 | 12:43 PM
Junglist's Avatar
Default Re: B18c5 lost motion assym. ? (D)
What is a LMA?
Old Feb 8, 2003 | 12:44 PM
ZygSpeed's Avatar
Oh well ...
What is a LMA?
Lost Motion Assembly -- part of what makes VTEC possible in Acura DOHC motors.
It provides the cam-following and locking mechanism for going from one set of cam lobes to the "VTEC" (bigger)cam lobes.
[Modified by zygspeed, 4:46 PM 2/8/2003]
Old Feb 8, 2003 | 12:45 PM
00MRSi's Avatar
Default Re: B18c5 lost motion assym. ? (Junglist)
What is a LMA?
Lost motion assembly. I do not know their purpose and function. D, SgT or anyone else care to explain LMAs function?
Old Feb 8, 2003 | 12:51 PM
Tweakmeister's Avatar
Default Re: B18c5 lost motion assym. ? (00MRSi)
boy, ed is mr. help today
Old Feb 8, 2003 | 12:52 PM
Junior_r's Avatar
part # 14820-P73-J01 LMA $29.19
Old Feb 8, 2003 | 12:54 PM
ZygSpeed's Avatar
Default Re: B18c5 lost motion assym. ? (Tweakmeister)
So is Mr. Junior R
Old Feb 8, 2003 | 12:55 PM
Junior_r's Avatar
Old Feb 8, 2003 | 01:00 PM
Kermit EK's Avatar
Default Re: B18c5 lost motion assym. ? (Junior R)
thanks!
Old Feb 8, 2003 | 01:42 PM
Hooch'n's Avatar
yep, everyone is all over this thread...
Old Feb 8, 2003 | 02:17 PM
sgT's Avatar
sgT
Default Re: B18c5 lost motion assym. ? (Hooch at 8400-RPM)
lost motion assembly acts as a third valve to keep the vtec rocker arm in contact
with the cam lobe when vtec is not in use
Old Feb 8, 2003 | 02:21 PM
00MRSi's Avatar
Default Re: B18c5 lost motion assym. ? (sgT)
Thanks SgT. for you.
Old Feb 8, 2003 | 03:32 PM
SlowPoke's Avatar
New User
how does the itr lma differ from other vtec ones?
Old Feb 8, 2003 | 03:37 PM
ZygSpeed's Avatar
Default Re: B18c5 lost motion assym. ? (SlowPoke)
I'd guess there are a little stronger due to the higher redline of an ITR.
Old Feb 8, 2003 | 03:53 PM
SlowPoke's Avatar
New User
ah, are they lighter in anyway? woudl that even help?
Old Feb 8, 2003 | 04:05 PM
ZygSpeed's Avatar
Lighter in this case would probably mean weaker.
Frankly, I defer to sgt"s expertise.
Old Feb 8, 2003 | 04:13 PM
sgT's Avatar
sgT
they have more mass so id assume they were heavier.
the spring inside is stiffer and the contact area is larger in order to handle
the extra rpm and lift.
Old Feb 8, 2003 | 04:46 PM
SlowPoke's Avatar
New User
nice thanks
trillione
Apr 21, 2017 06:15 AM
x8_andrew_8x
Northeast (Sales)
Mar 9, 2012 10:55 PM
yamamura
Feb 17, 2012 10:54 AM
roc
Aug 9, 2006 03:16 PM
AWDSOME
Dec 12, 2001 02:12 AM
