MSD in 94 LX
Do I need to leave the stock coil? And, do I just tap into the blk/yel and the wh/blu. (that is the wires inside the dis.)
[Modified by hmj88hb, 9:23 PM 2/8/2003]
is yours internal or external coil? my LX is external coil, but it's a 96, so i dont know if they changed with the years. this is the way i hooked mine up. my setup consist of MSD 6al and blaster 3 coil.
external coil: you dont need to mess with the dist. at all, you disconnect the stock coil, remove it (if you wish), tap the <FONT COLOR="red">RED</FONT> wire from the MSD box into the <FONT COLOR="yellow">YELLOW</FONT> and <FONT COLOR="yellow">YELLOW</FONT> / <FONT COLOR="black">BLACK</FONT> stock coil wires, tap the <FONT COLOR="white">WHITE</FONT> wire from the MSD box into the<FONT COLOR="green">GREEN</FONT> stock coil wire.
then the <FONT COLOR="orange">ORANGE</FONT> and <FONT COLOR="black">BLACK</FONT> wires from the MSD box go to the MSD coil.
internal coil: you'll need and MSD dist. cap.
[Modified by carolinaACCORD, 7:33 PM 2/8/2003]
