JDM H.I.D. type-r front
hey ya'll...i did a search but couldn't find anything...
i just picked up a a jdm type-r front with stock hid's...i heard that the ballast will not clear when the conversion is done, you'll (me) will have to relocate it...it that true? Please share...thanks in advance
peace
peace
peace
peace
umm... i did the HID conversion on my roomates 01 gsr wit no problem... i did have to bend the ac lines a bit, but no biggie, they are pretty flexible, jus make sure not to break em and to make sure they don't touch the power steering pulley belt. As for the other side, i didnt have a problem at all with the coolant overflow reservoir.
For 94-97, the larger ABS unit requires relocation of the ballast entirely i think.
Hope this helps guys.
Yeah, you will need to bend the hell out of your AC line. It's kind of a pain if you want to try and make it look clean. It dishraged my system and re-bent the line in question with a tubing bender. You can always just shoved it out of the way if you are not particular, just be careful as it is easy to snap the line if you get too agressive. I didn't do anything to the washer bottle other than shift back a bit.
Here are some old low-res pics of my install:
Passenger light
Driver's Side
Mike
Passenger light
Driver's Side
Mike
hwo about if u don't have AC
then its no problem
where does the coolant bottle get moved too
same place as stock?
[Modified by itr-j, 3:40 PM 2/10/2003]
then its no problem
thanks guys for the help...i have a 94 LS with ABS, soooo i will need to relocate the whole unit then, cause it seems like everyone that did this, they had a 98 and up integ...
thanks ya'll
peace
thanks ya'll
peace
Passenger light
Driver's Side
Mike[/QUOTE]
also, this helps alot thanks...any more pics? maybe pics of your car
dragnGSR
Feb 5, 2004 12:19 PM
