question about JDM conversion
Old Oct 10, 2002 | 11:16 AM
RiCE On IcE 2's Avatar
Default question about JDM conversion
I dind't find it in search. But seeing as the HID front end is leik 1000 more.. can you just get a regular conversion and get like a phillips HID kit and install it yourself? or is the house different with the HID JDM front end one?
Old Oct 10, 2002 | 11:18 AM
hungsteR's Avatar
Default Re: question about JDM conversion (scmdl26)
The housing on the HID headlights are different.
:edit: do a search on JDM HID or HID under the archives and you should find the answers to all your questions.
[Modified by hungsteR, 2:19 PM 10/10/2002]
Old Oct 10, 2002 | 11:20 AM
Default Re: question about JDM conversion (hungsteR)
I believe the regular housing is a projector set up right? I could elect to just get the regular front and then later put HID bulbs in there right? it would be basically the same as puting HIDS in a usdm right or is there some other problem with doing that?
[Modified by scmdl26, 9:23 PM 10/10/2002]
Old Oct 10, 2002 | 12:40 PM
Tommy_Gunns's Avatar
You will getting better results with the OEM HID housing.
If you've ever seen OEM HID, the light is spread evenly. The phillips kit on NON HID housings will have the same beam pattern as the Halogens except brighter.
Old Oct 10, 2002 | 01:23 PM
Default Re: question about JDM conversion (Tommy_Gunns)
coo thanx
EvoMperor
Apr 4, 2008 03:30 AM
jdmtyper680
Nov 18, 2002 10:09 AM
DA9-T
Nov 13, 2002 09:42 PM
ebelp
Sep 30, 2002 05:53 PM
JDMTEG98
Aug 20, 2002 11:06 AM
