Auto LS into hatchback...
hey all...first, i did a search and couldnt find what i needed....ok, heres the deal.....i have B18b from an automatic LS 'teg without tranny.....here's what i need from ya'll...i have a 92 civic vx, and i'm looking to swap in that b18b....what all would i need to make it compatible?? i KNOW i'll need ls MANUAL tranny, shift linkage and ECU...anything else??? axles?? mounts??? flywheel?? thanks in advance
[Modified by SpoonFedHatch, 9:55 PM 2/7/2003]
you got is... check out http://www.hasport.com for the fine details ie rad hoses.. blah blah blah
Guest
Posts: n/a
So you drive a spoon fed hatch?
Also, your title is a little confusing. Your not actually putting in the automatic transmission. You have the motor from a LS which was automatic. Now you just looking for parts ie. Manual transmission, alternator, starter, ecu.
