Greddy LS/GS turbo on my R
I emailed Greddy the other day and asked them (since the manifold set up on a B18B is the same as a B18C5) if the kit they have out for the LS would fit ok on my R. They said everything would bolt up right but the fuel management would mess everything up. Since I was planning on running hondata anyways i could use the LS kit on the R. Any opinions on this?
[Modified by 98cwitr, 3:03 AM 2/7/2003]
im only looking at running 7 psi and i want a turbo with very little lag...
You could also probably up the boost some, but you'ld be a little out of the most efficient range.
Will you be running an intercooler?
Yeah an intercooler is a must...the reason i really dont wanna go with the Drag III is because of the cheap *** intercooler...any suggestions?
That cheap *** intercooler (as you call it) fits nicely in the opening of my ITR.
What kind of suggestion(s) are you looking for?
The Greddy kit will work, but there's a reason they haven't released one for the ITR (lack of breating capacity and fuel control). Ed
I wouldnt think greddy intercooler would be any less efficient than drag - i didn't choose drag kit because of manifold, plus downpipe wouldn't work with inline pro manifold.
I went with t4B S (50 trim) compressor with t3 .48 a/r turbine stage 2 wheel.. - I plan to run 4.5-5psi. My other choice was T3 S60. Anything less than that didn't look efficient on top end based on compressor maps. Since itr motor flows pretty well, theres a little extra to consider which compressor maps may not tell..
quick question about turbo setups...Before I decided to go NA, I contemplated FI, but was told to steer away from a turbo because the turbos sit so close to the block, and are capable of causing damage to the block from overheating. you guys know any truth to that?
