leaking oil b/w oil pan and block....
like title says. i have a brand new honda gasket too. i was under there installing my engine stiffner (thanx len) and i noticed that the oil is seeping through.. its not reall a leak. now the helms manual doesnt say to put some formagasket aka liquidgasket on it.. should i?? i put 3 quarts of oil in there just to check it about 3 days ago.. what should i do.
thanx
[Modified by baonest, 8:53 PM 2/6/2003]
thanx
maybe the bolts are loose? just a thought
[Modified by baonest, 10:15 PM 2/6/2003]
Do not over torque, it can and will pinch the gasket, causing a leak. Yes, use hondabond, atleast on the corners. Also, if you put it on upsidedown, it will leak too. I am sure there are other things that can contirbute to it, but that is all I have experienced...
Jason
Jason
thanx for the info guys..
ill check tomorow to see how the "leek" is. where can i pick up some hondabond?? at honda dealer?
thanx
thanx
Do not over torque, it can and will pinch the gasket, causing a leak.do the raised dimples (on the contact surface) on the oil pan help prevent pinching?
Jason
