wierd dipstick reading? need some help
i bought my gsr like a month ago. ive had it in storage since then. i went to change my fluids today cause the guy said that it needed one when i bought it. when i checked the dipstick it didnt read that there was any oil at all. i drove it like 30 miles to school before i checked it and it was totally driving fine? whats up? thanks..
.. sharkey
.. sharkey
probably time to add some oil then, don't you think?
i highly doubt the dipstick is the problem
change your oil and fill it up to the "full" mark, usually a little over 4 quarts w/ filter
did you let it settle after you drove it? cause if not..then all the oil was still flowin around...
I believe on Hondas the distance between the two marks on the dipstick represents the change 1qt would make.
ie. if it's half way between the two marks, you need 1/2 qt.
You were probably just two quarts low. My Teg drinks oil. I don't think it burns it, because it doesn't have that Mitsubishi smell to it, but it does use it rather quickly for some reason. There's also no black smoke coming from the pipe.
Check for those things. Your best course of action is to do an oil change. Add 4 new quarts and change the filter, and monitor it. Check the oiul about every other day.
jonnyR
Jul 30, 2001 11:33 PM
