Shock question
Old Feb 6, 2003 | 03:44 PM
SOHC_MShue's Avatar
Default Shock question
if i lower my 98 coupe on either the Eibach Pro-Kit springs or the sportline springs is it going to be necessary to get new shocks?
Old Feb 6, 2003 | 04:03 PM
texan's Avatar
Default Re: Shock question (SOHC_MShue)
Not until the old ones go. The spring rates on Eibachs aren't very serious, but if you want the best possible suspension performance from your new setup, the stock shocks are completely inadequate (for serious performance driving).
Old Feb 6, 2003 | 04:07 PM
sslude's Avatar
Default Re: Shock question (texan)
i would recommend getting new shocks, it will be cheaper and more time consuming in the long run.
Old Feb 6, 2003 | 05:09 PM
SOHC_MShue's Avatar
Default Re: Shock question (sslude)
well if i am planning on running the stock shocks for a while should i just go with the pro-kit then?
Old Feb 6, 2003 | 05:12 PM
96 SOHC VTEC's Avatar
I ran Ground Control coilovers on stock shocks for a year before I got aftermarket ones. Ride was a little bumpy, but they were fine when I took them off.
Apr 16, 2009 10:46 AM
hastingsr
Suspension & Brakes
Aug 6, 2008 05:48 AM
liftandcut
Jan 6, 2006 10:33 AM
G_S_R
May 3, 2004 08:27 AM
Integra187
Mar 26, 2002 07:38 PM
