What is the difference between type R brake lines and regular integra lines?
I searched the archives and looked at acuraautomotiveparts.com What is the difference between these, and more importantly, which do I need for ITR brakes on a regular integra?
Thanks.
Kyle
[Modified by 2K_TEG, 2:02 AM 2/6/2003]
Thanks.
Kyle
according to helms manual, the only difference is the brake hose mounting bolt, but its the same on gsr and type r (98-01) but different from ls..
so the line is the same, it just bolts up in a different location. Meaning I can use LS lines and some zip ties w/o any problem?
I should have looked in my Helms, sometimes I forget what a good resource that is.
Thanks,
Kyle
Thanks,
Kyle
as far as i seen... only the mounting bolt is different.. there isn't a large section about brakes - i'd think i seen through everything...
abs on other hand is different - i think
a SET (4) of stainless goodridge lines is only 100$ from nopi. considering just one OEM line is 40-60 $, it kind of makes sense to do a brake line upgrade for less money. call nopi. ask for 97 Type R stainless lines. they will go right in.
I was planning on running my stock LS lines if I could pull it off.
Kyle
Kyle
