Some help with removing lights
As for removing the taillamp, all you have to do is remove the black plastic panel that is lining the inside of your trunk directly behind the tails. They are held in by a bunch of clips, push in the center alittle bit, and then pull the entire clip out, but be careful, those things are notorious for breakin on ya. Then you can see some long bolt ends stickin towards the inside of the car held on by some nuts, probably 10mm. Remove all of them, i think the 2 nuts on the way side are kinda harder to reach, after that just push the bolt ends from the inside of the trunk so that the taillamps pop out the back of the car, and thats pretty much it... oh yea, and you have to remove/unplug the wiring harness before it'll come out of the car i think, then you can remove the bulbs from the taillamp assembly if you need. You'll see what i'm talkin about once you do it.
I'm not sure what your talkin about the side blinkers... are you talkin bout the turn signals on the rear corner? Or the front bumper lens??
mtpktz.
Apr 2, 2007 08:33 PM
