Some help with removing lights
Old Feb 5, 2003 | 09:01 PM
prod19y's Avatar
Default Some help with removing lights
Does anyone know how to remove the tail lights of a 2000 Integra?
Also, how do you change the side blinker lights to clear? If i took them off a BMW would it fit?
Old Feb 5, 2003 | 10:23 PM
tC_Dragon's Avatar
Default Re: Some help with removing lights (Infamoz)
As for removing the taillamp, all you have to do is remove the black plastic panel that is lining the inside of your trunk directly behind the tails. They are held in by a bunch of clips, push in the center alittle bit, and then pull the entire clip out, but be careful, those things are notorious for breakin on ya. Then you can see some long bolt ends stickin towards the inside of the car held on by some nuts, probably 10mm. Remove all of them, i think the 2 nuts on the way side are kinda harder to reach, after that just push the bolt ends from the inside of the trunk so that the taillamps pop out the back of the car, and thats pretty much it... oh yea, and you have to remove/unplug the wiring harness before it'll come out of the car i think, then you can remove the bulbs from the taillamp assembly if you need. You'll see what i'm talkin about once you do it.
I'm not sure what your talkin about the side blinkers... are you talkin bout the turn signals on the rear corner? Or the front bumper lens??
mtpktz.
Apr 2, 2007 08:33 PM
armeck
May 12, 2004 09:34 AM
swatdog
Audio / Security / Video
Feb 1, 2004 09:45 AM
jaM3s Bond
May 6, 2003 09:04 AM
Chip398193
Dec 5, 2001 06:47 PM
