PR4-code 43
Old Feb 5, 2003 | 02:02 PM
Flexmyrex's Avatar
Default PR4-code 43
im getting code 43-Fuel suply system.
have any of you ran into this problem? i know this could be a few different things pump injectors etc. what could be my problem?
Old Feb 5, 2003 | 06:54 PM
Quick 200k Mile Motor's Avatar
Default Re: PR4-code 43 (flexmyREX)
I had this problem, same code throwing once in a while. I changed everything in the fuel system, filter, injectors, pump, and found out later on it was the O2 sensor signal. It was grounding out on mine.
Btw, the helms manual says code 43 is most likely a problem with the O2 sensor circuit.
Do you experience hesitation somewhere around 3000-3500rpm then after 4000rpm it runs great ?
Old Feb 5, 2003 | 07:16 PM
b19coupe's Avatar
Code #43 is usually the O2 sensor.
Old Feb 6, 2003 | 04:04 AM
Flexmyrex's Avatar
Default Re: PR4-code 43 (b19coupe)
ok i will check that, thanx b19coupe and quick 200k
yep it hesitates in the lower rpms
crxpwr1
Sep 9, 2008 03:27 AM
lance_ecl
Mar 6, 2008 08:27 PM
PhilStubbs
Jan 22, 2005 11:20 AM
dcsportsciv
10
Nov 12, 2004 06:44 PM
shalemain
Sep 23, 2004 08:07 AM
