blockguard
Old Feb 5, 2003 | 11:13 AM
booscivic's Avatar
Default blockguard???
Would a SOHC block with blockguard hold 300hp???? Do I need Sleeves??
[Modified by booscivic, 8:17 PM 2/5/2003]
Old Feb 5, 2003 | 11:18 AM
altoid's Avatar
Default Re: blockguard (booscivic)
you'll definately wanna sleeve that block, the only way you'll get 300hp out of your sohc is forced induction, in which case you'll need to upgrade the internals, or super high compression ratio in which case you won't be able to run your car without race gas. You're better off getting it resleeved. If you go for 300hp and you cut corners you'll never get there
eg6ajk's Avatar
just sleeve it if you can afford it. blockguard tends to put stress the motor by not allowing the cooling system to work properly. check on F/I forum for exact write up on setups and disadvantages.
Boostin Ex
Mar 11, 2003 04:18 PM
DXturbo
Feb 7, 2003 03:17 PM
PainfulTeg
Jan 18, 2003 07:10 AM
