recommended spark plugs for b18b
Old Feb 5, 2003 | 09:59 AM
dingusjt's Avatar
Default recommended spark plugs for b18b
i just did a swap and am wondering what spark plugs would be recommended...i'm looking to get a little better fuel economy being that i cam from an sohc engine.
Old Feb 5, 2003 | 10:01 AM
MR. ARIZONA's Avatar
Default Re: recommended spark plugs for b18b (dingusjt)
I'm wondering the same thing. I was going to get SPOON plugs and wires, but 276.00 for wires and 1xx.00 for plugs is waaaaaay to much for me.
Old Feb 5, 2003 | 10:22 AM
beaterman's Avatar
go to nopi.com go to the ecat section and search for your car. (what the motor would come in). and it will tell you which plugs are available for your motor.i got the stock ngk's in my 99ls.
Old Feb 5, 2003 | 10:25 AM
drewspeed's Avatar
Default Re: recommended spark plugs for b18b (beaterman)
NGK's work best. Not expensive either. Just don't go platinum
Old Feb 5, 2003 | 12:33 PM
Turbo Dreams's Avatar
Default Re: recommended spark plugs for b18b (drewspeed)
Yea stay with OEM NGK quality plugs. Good price
Old Feb 5, 2003 | 12:35 PM
StyleTEG's Avatar
Default Re: recommended spark plugs for b18b (Turbo Dreams)
Yeah, unless you are running FI there is no point to getting anything other than stock plugs and wires, you won't see a gain.
In fact, there is a ten second all motor B18 civic that runs on stock ignition.
Old Feb 5, 2003 | 03:04 PM
Ronin Integra8's Avatar
Default Re: recommended spark plugs for b18b (StyleTEG)
how come one shouldnt go with ngk platinium? whats the oem one? iridium or what?
Old Feb 5, 2003 | 08:21 PM
PandaBear's Avatar
Default Re: recommended spark plugs for b18b (Ronin Integra8)
Stock is Copper, why not platinum? it is more expensive and is not as good perfomance because copper is a better conductor. Only advantage of plat is longer life.
Old Feb 6, 2003 | 07:18 AM
EvilIntegrationLS's Avatar
Default Re: recommended spark plugs for b18b (PandaBear)
i have plantinums in my ls, and i also run NGK wires. like they said, you can't feel a gain, but no complaints here expcept $12+ per plug but i got mine at nopi also, because they are down the street for me, but they're a little pricey.
[Modified by EvilIntegrationLS, 4:23 PM 2/6/2003]
Old Feb 6, 2003 | 09:54 AM
tC_Dragon's Avatar
Default Re: recommended spark plugs for b18b (EvilIntegrationLS)
hey, you don't have to order the oem ngk's from nopi... with shipping n all.. it'd be cheaper probably goin to ur local kragen's. It was around like 1.75 a pop for me.
Old Feb 6, 2003 | 10:24 AM
94ls's Avatar
i had asked a general q about what other G3 teg owners are using for plugs..i found out you ought to just get the OEM plugs. In fact you don't even need to get em from honda/acura. Go to advance auto parts have em pully the car in the computer and bam..ur good..i believe they're the NGK coppers. they'll work fine...
Old Feb 6, 2003 | 01:51 PM
darrinbrewer's Avatar
Default Re: recommended spark plugs for b18b (94ls)
i put a set of msd 8.5mm plug wires on my gsr...starts up WAAAYY quicker -starter hardly has time to turn over..
digitalvice
17
Mar 25, 2013 03:14 PM
central_driver
Feb 5, 2006 09:37 AM
AllMotor12s
May 19, 2004 02:30 PM
jdmjeff
12
Nov 20, 2003 01:26 AM
hybrider
Apr 25, 2002 06:44 AM
