Do I need to use Honda brand products for brake fluid and antifreeze?
Old Feb 4, 2003 | 08:35 PM
UncleRay's Avatar
Default Do I need to use Honda brand products for brake fluid and antifreeze?
Good God! I have been reading the manual that came with my 2000 Accord and it says to use Honda brand fluids for not only auto tranny, but brakes and cooling system as well! I believe the tranny fluid from Honda is a necessity, but come on can't the Honda hold up as well with some non-dealership fluids as some Toyotas do. I never was aware of these recommendations beforehand or I might not have a Honda in my garage now! Thanks.
Ray
Old Feb 4, 2003 | 09:47 PM
XxWildHorsexX's Avatar
Default Re: Do I need to use Honda brand products for brake fluid and antifreeze? (UncleRay)
not even the dealer uses honda coolant they use shell coolant ... but the tranny oil is a item i wouldnt buy anywhere else but the dealer brake fluid is just the same anywhere you get it just buy the right type
Old Feb 5, 2003 | 03:36 AM
KGAccord's Avatar
Default Re: Do I need to use Honda brand products for brake fluid and antifreeze? (XxWildHorsexX)
power steering fluid is another fluid that should be honda only
brake fluid and coolant can be non-honda
atf or mtf, is probably a good idea to use honda fluid
Old Feb 5, 2003 | 05:01 AM
jweller's Avatar
Default Re: Do I need to use Honda brand products for brake fluid and antifreeze? (KGAccord)
There was a discussion on the honda coolant a few months back in the tech forum and the general consesus was that using an improperly formulated coolant could cause head gasket problems. I'm not willing to chance that. I just use the Honda brand coolant because I KNOW it has the correct formulation. I've got no idea if the stuff off the shelf does or not. I've never heard that Honda dealers use shell coolant. a more likely scenario is that Shell manufactures coolant for honda based on hondas specifications.
Honda MTF is definately different than any other MTF i've ever seen before. It kinda smells like mineral oil. no idea on the atf.
you can use any DOT 4 Brake fluid.
Old Feb 5, 2003 | 06:52 AM
Desslok's Avatar
Default Re: Do I need to use Honda brand products for brake fluid and antifreeze? (jweller)
For Brake fluid get whatever meets specs. For antifreeze, you need to use the right type to avoid damage to seals, head gasket, etc. Has to do with phosphate levels, etc. I'm sure there are ones at Pep Boys that will work, since Honda doesn't make theirs, but I am usually at the dealer anyways to get oil filters, etc, and the coolant isn't much more than at Pep Boyz anyways. I'd rather pay $2 more and have the peace of mind that I got the right one, and don't have to worry about premature seal failure.
Old Feb 5, 2003 | 07:11 AM
johnsaccord's Avatar
Default Re: Do I need to use Honda brand products for brake fluid and antifreeze? (Desslok)
For brake/clutch fluid I use geniune honda, as well as tranny fluid, for antifreeze I use Prestone (think it's better).
[Modified by johnsaccord, 11:12 AM 2/5/2003]
tpot90
Jan 12, 2008 11:04 PM
vdg721
Oct 25, 2007 12:30 PM
Jimmy604
Jun 22, 2007 11:52 AM
jdmludeaz
Apr 11, 2006 05:05 AM
cdansl
Jul 2, 2005 05:30 PM
