Anyone upgrade the bushings on their front swaybar?
Old Feb 4, 2003 | 08:30 PM
. o 69 o .'s Avatar
Default Anyone upgrade the bushings on their front swaybar?
Im looking to do the bushings instead of swapping out the front bar. I am considering Energy suspension or prothane. Anyone try these out?
Old Feb 4, 2003 | 08:42 PM
bikeboy80's Avatar
Default Re: Anyone upgrade the bushings on their front swaybar? (B16B)
i would tell you how my es ones are but they have been on back order for over 2 months now
if the car is a few years old it could probally help a bit
[Modified by bikeboy80, 12:43 AM 2/5/2003]
Old Feb 5, 2003 | 05:59 AM
96IntegraLS4DR's Avatar
Yes I did.
It tighten up steering a *tiny* bit.
But that was not the reason I replaced it.
I did it because it lasts longer then stock rubber bushings.
Old Feb 5, 2003 | 06:16 AM
Farnsrocket's Avatar
Default Re: Anyone upgrade the bushings on their front swaybar? (96IntegraLS4DR)
For my 95 Teg, Neuspeed makes just the bushing kit.
Old Feb 5, 2003 | 08:15 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Anyone upgrade the bushings on their front swaybar? (bikeboy80)
I bet you could have gone to your local AutoZone and bought them. The AutoZone here where I go to school (very small town) carries the ones w/ the grease fittings on the brackets.
Old Feb 5, 2003 | 08:20 AM
emr88's Avatar
Default Re: Anyone upgrade the bushings on their front swaybar? (PatrickGSR94)
I did because mine were all worn and cracked. Didn't really notice much of a difference in handling though. They are cheap and easy to swap out.
Here is the thread from the archives
https://honda-tech.com/zerothread?id=354882
[Modified by emr88, 11:07 AM 2/5/2003]
Old Feb 5, 2003 | 10:01 AM
bikeboy80's Avatar
well unfortunatly I because it was a special order item i had to pay in full before i ordered and its not refundable
Old Feb 5, 2003 | 03:06 PM
. o 69 o .'s Avatar
i can get the prothans endlink bushing kit for about $35 canadian dollars, and the sway bar bushing kit for $15 canadian with no back order time. question is... is this a worthwhile $50 upgrade? car is a 95 teg
This will eventually be used in conjunction with a ITR rear sway bar so essentially im just trying to balance it out a bit
Old Feb 6, 2003 | 08:01 AM
emr88's Avatar
Not much of a benefit for the $50. If it cost you that much, I'd opt for the factory rubber pieces as replacements instead, shouldn't cost you more than $20.
Old Feb 6, 2003 | 09:19 AM
ALF's Avatar
ALF
I put some ES front swaybar bushings in after installing my ITR rear swaybar. Before putting in the bushings, low-speed turns felt somewhat sloppy in the front. But keep in mind, this was for everyday driving <edit>and my car's OEM bushings were worn after 7 years</edit>. Pushing it hard through the turns, I felt the effects of the ES bushings considerably. The car stays planted, without a doubt. But, acceleration-wise, when going through turns, the car was slower. In my mind, this was due to the slight increase in understeer brought about by the upgraded bushings. So to counter this, I chose to adjust the settings on my shocks. It is now a little better...and I even thought about swapping the ES bushings for some new OEM ones. For now, sacrificing slightly faster turns for flatter low-speed everyday turns is a fair trade-off.
If I could do it over again, I would opt for some OEM bushings. Or better yet, get the ES bushings, but with the 23mm rear swaybar.
Hope this helps...
[Modified by ALF, 1:20 PM 2/6/2003]
Old Feb 6, 2003 | 09:32 AM
Typiko512's Avatar
Default Re: Anyone upgrade the bushings on their front swaybar? (ALF)
energy suspension kit fit both my ST front/rear sway bar bushings. Big improvement. Very impressive.
Chimichanga
Jul 31, 2008 10:35 AM
wicked2night
Dec 31, 2006 07:34 AM
ludesrv
Jun 1, 2006 09:56 PM
ITR1299PR
Dec 21, 2003 03:26 PM
comptechgsr
Jun 2, 2002 04:32 AM
