Finished my rear install
Old Feb 4, 2003 | 05:51 PM
Dee's Avatar
Dee
Default Finished my rear install
Headunit shots will come later after I chnage to the MD/TV unit!
Alpine TV Headunit and EQ
Alpine 5 channel amp
MB Quarts seperates front and rear
JL Audio sub
The black box on the right is an HKS CAMP
The black box on the upper left is a 12v/110 power converter for my laptop and other crap.
I'm happy with the sound it produces and the only thing I didn't do myself was carpet the sub box .
Before
MDF for the sub box
Board for the amp and other crap
Almost done
Initial test fitting
Crossovers for the front MB Quart set
It's complete!!
Old Feb 4, 2003 | 05:53 PM
Dee's Avatar
Dee
Default Re: Finished my rear install (Dee)
I had a problem with the RCA's so they have been changed!
Old Feb 4, 2003 | 06:56 PM
vteg's Avatar
New User
What did you use to hold the crossovers on the door cover? putty?
Since you don't have rear seats, do you cover the hatch opening somehow so the sub cannot be seen.
Old Feb 4, 2003 | 07:34 PM
Dee's Avatar
Dee
Default Re: Finished my rear install (vteg)
There were three existing screw tabs on the panel so I filled the tabs with epoxy screwed the plywood crossover mount into the tabs before the eposy set. The crossovers can be easliy removed but the mount will require cutting to remove. I still use the hatch cover and I have a sun screen for the rear section when the car is parked.
Old Feb 5, 2003 | 10:08 AM
Resurgent's Avatar
Look pro ! nice choice in goods
Did you bolt the sub down ?
Old Feb 5, 2003 | 11:37 AM
Dee's Avatar
Dee
Default Re: Finished my rear install (Resergent'a)
I purposely made the bottom board 1/2" longer on each for retention. In one of the pics you will see a silver U-bolt protruding through the carpet. There are actually two of tehse with one in the front and one the rear to control front to rear movement. There are two custom bent brackets on each side of the box that prevent side to side movement while also keeping the box secured to the plywood spare tire cover that is bolted to the car. The box can be easily removed for race events but also will not move around when I hit big bumps in the road.
I'll try to get some better pics soon. The plywood sparetire cover is a two piece unit that has plenty of bracing to support the weight of the amp and box.
Old Feb 5, 2003 | 05:38 PM
JOMO
Guest
Posts: n/a
yawn...
j/k, man that is cool, how does it sound?
Old Feb 5, 2003 | 08:09 PM
Dee's Avatar
Dee
Default Re: Finished my rear install (JOMO)
Sonds pretty damn good. I have been using MB Quart component speakers for a while and the JL Audio 10" sub produces clean soild base. I built a .8cuft box according to JL Audio's specs. I mainly wanted something that would drown out the sound of my exhaust while cruising on this resort filled ROCK
Old Feb 5, 2003 | 08:17 PM
J.P. 4rm The dPk*'s Avatar
on your custom trunk
Old Feb 6, 2003 | 01:43 PM
n0 iNTegRiTY's Avatar
nicely done
Old Feb 6, 2003 | 05:16 PM
Dee's Avatar
Dee
Default Re: Finished my rear install (RAF LTD. 2)
Thanks guys!
Old Feb 6, 2003 | 10:25 PM
gsxr's Avatar
nice, how do you like your rear strut bar? did you get it before the rollbar? and how much did ya get it for?
Old Feb 7, 2003 | 02:40 AM
Dee's Avatar
Dee
Default Re: Finished my rear install (gsxr)
I got my front and rear Carbing tower bars when I setup the initial Honda-Tech Carbing group buy last year. I don't even remember how much I paid for it...hahahaha. I have always had tower bars and rollcages in my Honda's but the bars always come before the cages.
s2vtek
Mar 10, 2008 04:28 AM
DeadLock23
Northeast (Sales)
Mar 14, 2006 12:04 PM
CrazyModGSR
Audio / Security / Video
11
Dec 23, 2004 07:10 AM
jordan-boxer
Apr 22, 2004 09:52 PM
rainmanEK
May 21, 2003 06:45 AM
