2hp compressor enough to keep valves up????
Old Feb 4, 2003 | 04:54 PM
GreenD's Avatar
Default 2hp compressor enough to keep valves up????
whats the minimum, recomended psi for this procedure?
tia
Old Feb 4, 2003 | 05:18 PM
kb58's Avatar
Banned
Default Re: 2hp compressor enough to keep valves up???? (GreenDestiny)
Air compresser hp has nothing to do with it because there is no air flow required. Any compressor will do.
Old Feb 4, 2003 | 05:34 PM
Nameless RB26's Avatar
Default Re: 2hp compressor enough to keep valves up???? (kb58)
yah.. but this is 2 whole horseys.
I bet it'll work as long as it's sealed properly. Be carefull
Old Feb 4, 2003 | 05:51 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: 2hp compressor enough to keep valves up???? (Nameless)
it will work fine. It just has to build up enough pressure to keep those puppies up, and then be able to keep them like that without having any leaks.
Old Feb 4, 2003 | 06:16 PM
Shawn C's Avatar
In The Garage
Default Re: 2hp compressor enough to keep valves up???? (Emerica)
what are you guys talking about??
Old Feb 4, 2003 | 06:23 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: 2hp compressor enough to keep valves up???? (22lbGS-R)
pushing compressed air into the spark plug hole to keep the valves seated to remove springs/retainers
Old Feb 4, 2003 | 08:55 PM
StorminMatt's Avatar
SCC had another way of doing this without compressed air when they did a cam change on their Neon project. They filled the cylinder with rope and brought it close to TDC. The rope compressed up against the valves and held them closed. Just be sure (1) that you use a rope that does not shed fibers (use something like nylon and NOT hemp), and (2) that you leave a generous length of rope coming out of the spark plug hole. Otherwise, you might find yourself pulling your head off to remove the rope.
[Modified by StorminMatt, 5:55 AM 2/5/2003]
Old Feb 4, 2003 | 09:36 PM
delslow94's Avatar
Default Re: 2hp compressor enough to keep valves up???? (StorminMatt)
i just continuously moved the pistons to tdc when i did mine. worked just fine. just do cylendars 1-4 and 2-3 together and it will be fairly efficient. the valves wont drop but a little bit and give you more than enough room to do the work.
socialistic
22
Jul 28, 2011 01:32 PM
JBirch_97Prelude
Nov 3, 2008 08:23 AM
02vtecsir
Mar 27, 2008 04:44 PM
GsR92HaTcH
Dec 20, 2006 09:11 PM
boosted k20
Aug 20, 2004 12:12 PM
