Rubbing issues with my wheel/tire combo?
Old Feb 4, 2003 | 03:28 PM
BlueR's Avatar
Default Rubbing issues with my wheel/tire combo?
i will be installing my mugen lowdowns this weekend,
this will theoretically drop the R 3/4in all around
my 16x7 te37s ( thanx to Batoutahell) with 215/45/16 Azenis will go on next week
this will basically be my track setup for the upcoming year
will i have any rubbing issues with this setup?
Old Feb 4, 2003 | 03:31 PM
donnie B's Avatar
Default Re: Rubbing issues with my wheel/tire combo? (BlueR)
what is the offset on the wheels?
Old Feb 4, 2003 | 03:33 PM
pleiades nutz's Avatar
You might experience slight rubbing while on the Track but day to day driving I say no. I have Spoon Springs and I rub very slightly during hard cornering and I beleive the Lowdowns aren't as extreme of a drop, good luck.
Old Feb 4, 2003 | 03:35 PM
BlueR's Avatar
Default Re: Rubbing issues with my wheel/tire combo? (donniEK)
i have to double-check the offset
rubbing on which corner?
Old Feb 4, 2003 | 03:39 PM
Here is the best pic I have of the clearence, hope it helps......I rub in the rears only, about 1 inch in the center of the well.
Old Feb 4, 2003 | 03:42 PM
Batoutahell's Avatar
The offset on the volks is +42. For what it's worth, the volks with 205/45/16 Yokohama A520's didn't even come close to rubbing on my car (I have the lowdowns also). Granted, I never tracked the volks, but I did autoX with them once with no clearance problems.
Old Feb 4, 2003 | 03:44 PM
BlueR's Avatar
Default Re: Rubbing issues with my wheel/tire combo? (oRgy)
did you do that at the track?
i don't think the lds with produce that much of a drop in the rears
the spooms are notorious for their low rear drop
nice wheels by the way
Old Feb 4, 2003 | 03:45 PM
BlueR's Avatar
Default Re: Rubbing issues with my wheel/tire combo? (Batoutahell)
ah, there you are
thanx for chiming in jim
Old Feb 4, 2003 | 03:58 PM
thanks
I rub on the streets as well but very rarely, not enough to cut into the rubber or anything like that........I think you'll be ok with the lowdowns.
Oh yeah, I rub on the outer sidewall of the rear tires.
[Modified by oRgy, 7:06 PM 2/4/2003]
Old Feb 4, 2003 | 05:17 PM
BlueR's Avatar
thanx again for your input dude
AamirCWITR
Aug 6, 2004 10:14 AM
DownBoyDown
Oct 8, 2003 07:48 PM
doubledown
May 21, 2003 09:47 PM
MRDC2
Feb 21, 2003 05:33 PM
mattL
Jan 17, 2002 08:44 AM
