wheel offset question
Old May 21, 2003 | 07:53 PM
doubledown's Avatar
Default wheel offset question
which offset would work better on gsr with 1.5in drop with 16x7 wheels? +40mm or +45mm. Thanks
Old May 21, 2003 | 08:18 PM
tilt's Avatar
Default Re: wheel offset question (doubledown)
Tire profile also matters. With 205/45 you should be ok with either 40 or 45 offset since you arent dropped a lot. With 215/45 like the Azenis, the best offset is actually about 42-43mm. You can go 45mm and get some 2-3mm spacers if it ends up rubbing on the inside or get the 40 and see if you have to roll the fenders to clear the outside.
Old May 21, 2003 | 08:55 PM
doubledown's Avatar
Default Re: wheel offset question (tilt)
would I be able to fit 205/55's with either one?
Old May 21, 2003 | 09:47 PM
Volcom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">Tire profile also matters. With 205/45 you should be ok with either 40 or 45 offset since you arent dropped a lot. With 215/45 like the Azenis, the best offset is actually about 42-43mm. You can go 45mm and get some 2-3mm spacers if it ends up rubbing on the inside or get the 40 and see if you have to roll the fenders to clear the outside. </TD></TR></TABLE>
Very good advice Tilt. I have +40 16x7 slipstreams and plan on running the 215 azenis one day. I couldn't get the steel grey in a +45. I went with the +40's and will probably have to roll the fenders to get them to fit. Planning is key when it comes to expensive things like wheels and tires.
ridin98civic
Dec 29, 2006 12:12 PM
99fbpem1
Aug 25, 2006 04:59 PM
1gEF-8
Jul 2, 2005 03:33 PM
FrostyDC4
Apr 2, 2005 11:03 AM
mattL
Jan 17, 2002 08:44 AM
