Battery light on after alternator swap
Old Feb 4, 2003 | 02:31 PM
raene's Avatar
Default Battery light on after alternator swap
My battery light's on after the alternator swap! I just put in a brand new battery and a rebuilt alternator from a '90 Teg LS (into CRX Si w/ a B16A). I'm getting 14+ volts reading on the voltmeter (that I also just installed) right from startup, and 14.5 volts on the handheld multimeter.
Also the 'check battery' light flickers when the car's taken up past 3000rpm or so, like it's turning on and off, though there's no voltage change... I already tightened the alternator belt also WTF??
[Modified by raene, 3:32 PM 2/4/2003]
Old Feb 4, 2003 | 04:35 PM
tominos's Avatar
Default Re: Battery light on after alternator swap (raene)
as you rev past 3000, isn't voltage from the alternator suppose to go up a little bit?
Old Feb 4, 2003 | 05:12 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: Battery light on after alternator swap (tominos)
u should not be getting 14.5 with the car just idling u should be getting that at like 1500 to 2000 maybe your alternator is over charging the battery thats why u might have the light flicking on and off and did u check all the connection and made sure the alternator is grounded properly that can be causing the problem
Old Feb 4, 2003 | 05:46 PM
raene's Avatar
Default Re: Battery light on after alternator swap (streetdreams02)
CRAP, that'll kill the battery huh? Damn.... I guess I'll have to doublecheck the grounding thing; I don't see how it can not be grounded, but... I don't know...
Old Feb 4, 2003 | 08:50 PM
raene's Avatar
TTT
Any ideas? Bad regulator?
I checked resistance to ground - 0.8 ohms, and 0.8 ohms to power from power.
Old Oct 23, 2008 | 01:26 PM
eg_type_r93's Avatar
sometimes when the alternator belt is to tight the alternator over charges the battery and throws a code.
Old Oct 23, 2008 | 08:13 PM
srmofo's Avatar
Default Re: Battery light on after alternator swap (eg_type_r93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 &raquo;</TD></TR><TR><TD CLASS="quote">sometimes when the alternator belt is to tight the alternator over charges the battery and throws a code.</TD></TR></TABLE>HUH? No it doesn't
Old Oct 24, 2008 | 04:21 AM
King V's Avatar
Default Re: Battery light on after alternator swap (srmofo)
Only time you get charging system issues that are belt related is when the belt is too loose. Could have a crap rebuilt alt or the harness its plugged into might have some problems(broken wire,etc).
Dj HeetazMalone
Classic Hondas
Jun 15, 2017 07:24 AM
Spencerk10
Sep 13, 2015 08:48 PM
Lissav
Feb 2, 2008 03:58 PM
fe519
Sep 23, 2003 03:25 AM
pstutz
Apr 26, 2003 12:05 PM
