????? Blk/Yel and Blue wire on Dist.....?????
Old Feb 4, 2003 | 06:51 AM
ZColeon's Avatar
New User
Default ????? Blk/Yel and Blue wire on Dist.....?????
Just checking but the Blk/Yel wire on the 2 wire plug on Dist. comes from the 8 wire plugs near the injector resistor box right? And the Solid blue in the same 2 wire plug on Dist. Comes from the the same 8 wire plug?(Tach Wire)
Hoping someone may be able to confirm?? I pretty sure but the blue is the only one in question. Blk/Yel has volts, but Solid blue dose not. ( or maybe it does only when the motor is firing in conjunction with the injectors?????
Old Feb 4, 2003 | 09:34 AM
ZColeon's Avatar
New User
Default Re: ????? Blk/Yel and Blue wire on Dist.....????? (ZColeon)
got it running!!!!!!!!!!!!!!!!!!!!!!!!!!! Now i need ICS, ICCV, ICD, IAB check valve,
The idle is flucuating alot, and a couple of vacums are still open, The ECT isnt working on my dash,
And my check engine light is on, not sure on how to check codes on a lude, Anyone???
94typeR
Mar 27, 2007 11:04 AM
BOMBCRU
Apr 11, 2006 06:29 AM
I8ayellowcrayon
May 24, 2004 08:21 PM
arjusmc
Jul 2, 2003 03:57 AM
cw_civic
Audio / Security / Video
Jun 19, 2002 08:21 PM
