best place for oil pressure sending unit?
Old Feb 4, 2003 | 12:29 AM
ponykillergsr's Avatar
Default best place for oil pressure sending unit?
I have an auto meter oil pressure gauge, but I am not sure where I should put the sending unit. Does anyone have one installed.
Old Feb 4, 2003 | 08:51 AM
Trac226's Avatar
Default Re: best place for oil pressure sending unit? (ponykillergsr)
I think the easiest place for you to do it is where the oil sending unit connects to the block.
Old Feb 4, 2003 | 08:59 AM
integra-modder's Avatar
Default Re: best place for oil pressure sending unit? (Trac226)
If you ever plan on going turbo or doing LS/VTEC, might as well get one of these:
https://honda-tech.com/zerothread?id=384534
Old Feb 4, 2003 | 10:14 PM
Is there an untap'd oil supply port any where on the block???
Old Feb 5, 2003 | 05:08 AM
PM-Performance's Avatar
yea what you do is take out the factory oil pressure sender, its right next to the oil filter and has like a rubber plug over it , takwe that off, its a 15/16 deepwell socket, and in place you need an autometer atm-2269 which is the 1/8 bspt to 1/8 npt fitting for the sending unit to go into the bakc of the block .
hope that helps
Old Feb 5, 2003 | 07:54 AM
AK94GSR's Avatar
Default Re: best place for oil pressure sending unit? (itr206)
Check this link out:
http://www.theoldone.com/articles/oilpressure/
Old Feb 5, 2003 | 08:53 AM
drewspeed's Avatar
Default Re: best place for oil pressure sending unit? (AK94GSR)
That's the link I used - very thorough.
Old Feb 5, 2003 | 09:02 AM
AzG35's Avatar
The problem with putting the unit on the block itself is that its heavy. I've numerous sending units break off because of vibration and jerking of the motor. I would do the the endyn article and run a line from the block to the firewall instead of straight off the block. This doesn't put as much tension on the threads and is
twentyhurtz
Dec 7, 2008 09:17 AM
aleks77
Jun 8, 2007 05:46 AM
JokerX-1.6T
May 19, 2007 02:01 PM
Rod.
Jul 29, 2004 11:30 AM
Bspec18
Oct 14, 2003 11:47 PM
