"hum" noise when driving forward Prelude 2001
Old Feb 3, 2003 | 09:50 PM
dnguy14's Avatar
Default "hum" noise when driving forward Prelude 2001
My Prelude 2001 makes a "hum" noise (about 3 seconds) everytime when driving forward (from park). Does anyone has the same problem? Is this normal? Thanks
Old Feb 3, 2003 | 10:38 PM
caLiH22A's Avatar
Default Re: "hum" noise when driving forward Prelude 2001 (dnguy14)
mine does that too, I notice it everytime when I go foward after backing up and turning the wheel. I have no clue what it is, but i guess it's normal.
Old Feb 4, 2003 | 04:28 AM
714's Avatar
714
Default Re: "hum" noise when driving forward Prelude 2001 (caLiH22A)
My 93 Si does it, but only the first time going forward after startup, it sounds like a fuel pump hum, but I dont think thats it.
Old Feb 4, 2003 | 04:49 AM
piotrush's Avatar
Is your lude an SH? Mine is and as far as I know its the atts pump.
Old Feb 4, 2003 | 06:21 AM
743's Avatar
743
Default Re: "hum" noise when driving forward Prelude 2001 (piotrush)
the dealership said that it is an abs check or a brake check of some sort. And i have a 2000 base model so i dont think that its related to atts.
[Modified by -SevenFourThree-, 10:22 AM 2/4/2003]
Old Feb 4, 2003 | 07:00 AM
kidaniel's Avatar
Yes it's normal, just your ABS
[Modified by kidaniel, 8:01 AM 2/4/2003]
Old Feb 4, 2003 | 01:30 PM
prelude22085's Avatar
Default Re: "hum" noise when driving forward Prelude 2001 (kidaniel)
Ya you are right, I checked with Honda ,because my car was doing the same, and they also said that it was ABS. I have a 92 Si.
Old Feb 4, 2003 | 02:50 PM
piotrush's Avatar
Default Re: "hum" noise when driving forward Prelude 2001 (-SevenFourThree-)
hmm, does this only happen when you first move after starting the car? or every time you start from a stop even without starting the car?
Old Feb 4, 2003 | 03:09 PM
kidaniel's Avatar
It should only do it when you start your car and drive away, not everytime you start moving from a stop. When you slam on the brakes the ABS will kick in and then you will feel/hear the ABS charging up again.
Nhannerds
Nov 1, 2006 10:51 AM
TCPRELUDE
Mar 29, 2005 11:26 AM
Mike1486
Jan 17, 2005 01:20 PM
fiebru1119
Mar 7, 2002 01:13 PM
Mr. Softee
Sep 10, 2001 05:56 PM
