Changing ABS Module Need Help.
Old Feb 3, 2003 | 08:44 PM
E46M3CB's Avatar
Default Changing ABS Module Need Help.
Hi guys need your expertise...
I have a 95 GSR and I am looking to upgrade my ABS modulator (The one in the engine bay) to the ITR one since i've read from past post that the ITR is much better. Well the question I want to ask is if I switch it out, will i need to replace the lines also? What about my ECU and ABS Unit (the one located in the back of the trunk passenger side) Thanks for your help.
Also one last question... There's method to increase HP... but how can I increase TQ? I have a 96 JDM ITR Motor...
Thanks.
Old Feb 3, 2003 | 08:49 PM
migs's Avatar
Default Re: Changing ABS Module Need Help. (serenity)
Yikes, Might be cheaper to convert to non-ABS (Integra RS spec) thats why I did. Leaves a HUGE amount of space too. You can practically sleep in there
Also, to increase tq, not by numbers, but be feel, get a 4.785 98+ tranny. You probably have the 96 spec which is 4.40
Old Feb 4, 2003 | 06:49 AM
GM2000ITR's Avatar
New User
In case you're still looking, check my sig below. I'm selling everything you will need. -Greg
[Modified by GM2000ITR, 1:12 PM 2/4/2003]
Old Feb 4, 2003 | 10:35 AM
migs's Avatar
Default Re: Changing ABS Module Need Help. (GM2000ITR)
What prop valve are you selling him? Integra RS?
Old Feb 4, 2003 | 10:48 AM
BabyBadassIntegraGSR's Avatar
Default Re: Changing ABS Module Need Help. (Migs)
Yes, the lines are different. You need the ITR hard lines and MC. Im still trying to find out about the wiring. Im in the same boat as you with my GSR.
Old Feb 4, 2003 | 10:49 AM
sgT's Avatar
sgT
ABS cars dont have prop valves last time i checkd
Old Feb 4, 2003 | 10:54 AM
migs's Avatar
Default Re: Changing ABS Module Need Help. (sgT)
Sakai, your'e right. The "Prop Valve" is in the modulator. That why I ask what kind of prop valve he has, more than likely I hope, RS spec
Old Feb 4, 2003 | 11:17 AM
GM2000ITR's Avatar
New User
My bad...I meant distribution block located behind the IM. Sorry about all the confusion. Basically, I am selling my ITR MC, ITR brake lines, ITR "distribution block", and ITR ABS module. All in working order (still in my car). $350 + shipping........first come, first serve.
Old Feb 4, 2003 | 10:09 PM
E46M3CB's Avatar
thanks for the replies guys... Wow seems like its more work that I originally had intended to do...
What do you guys recommend? Keep my GSR ABS or Upgrade to the ITR one?
Thanks Peeps
Old Feb 4, 2003 | 11:36 PM
migs's Avatar
Get rid of it.
nfieldzy12
Mar 20, 2013 06:50 PM
Jeff_B
Oct 17, 2004 11:25 AM
Jonathan_ED3
May 28, 2004 10:13 PM
lilcaliplayany
Dec 27, 2003 06:00 PM
Swift
Nov 25, 2003 03:56 AM
