Car won't start? What could the problem be?
Car won't start unless being jump started... I've already tested out the Battery and alternator and everything looks normal. What could the problem be? I do notice my lights flickering when the car is on.... Do any of you guys have a clue on what it could be? thanks
If it only start when jump starting it would almost have to be the battery. If it was anything else it would start either way would it?
Your not getting enough power to charge your battery. Make sure your terminals are tight on the battery, double check your alternator wires, and dont forget the negative wire.
This car is a 98 EK. All grounds are clean and secured. I'm thinking its the alternator but its pumping out 15 on the volt meter. Could it be the distributor?
selasornayr
Jun 28, 2005 02:53 PM
BeavisB16
Sep 18, 2003 06:08 AM
