96-98 and 99-00 dash compatibility....
Old Feb 3, 2003 | 12:31 PM
4g4me's Avatar
Default 96-98 and 99-00 dash compatibility....
Are the two named dash pads the same? I know that they LOOK the same, but I hate to attempt a swap and have the newer one be a little different. I would be pretty angry. Can anyone tell me if they are the same?
Old Feb 3, 2003 | 12:35 PM
Nameless RB26's Avatar
Default Re: 96-98 and 99-00 dash compatibility.... (4g4me)
Dash pads?
Are you talking about the climate control console area thingy mabob doodadily hotdoggity dip?
Yah, I don't think it plugs in right..
Old Feb 3, 2003 | 12:54 PM
b16 matt's Avatar
Default Re: 96-98 and 99-00 dash compatibility.... (Nameless)
if your talking about the dash itself yes they are. I f*&*ed mine up in my 99 and put a 98 in it...
Old Feb 3, 2003 | 01:09 PM
qcoffey's Avatar
Default Re: 96-98 and 99-00 dash compatibility.... (b16matt)
If you are refferring to the center climate control system these are not compatible. The 96-98 climate controls are of the slide lever variety, where as the 99-00 are controllled by dials that use electronics to open and close vents, etc.
If you are reffering the the guage cluster then yes those are compatible.
Old Feb 4, 2003 | 05:58 AM
4g4me's Avatar
Default Re: 96-98 and 99-00 dash compatibility.... (qcoffey)
I was refering to the dash pad alone. The a/c controls and everything else will be staying the same.
Old Feb 4, 2003 | 01:06 PM
b16 matt's Avatar
It will work!!!!!!!!!!!!!!!!
Old Feb 4, 2003 | 01:11 PM
qcoffey's Avatar
Old Feb 4, 2003 | 04:16 PM
I still don't understand what a dash pad is. Were you talking about the dash board as a whole?
tominos's Avatar
yea, whats a dash pad?
Old Feb 4, 2003 | 04:30 PM
Default Re: 96-98 and 99-00 dash compatibility.... (tominos)
When I think of pads, something else comes to mind .
Maybe I'm narrow minded...
Old Feb 7, 2003 | 07:15 AM
4g4me's Avatar
when you remove a dashboard, the unit comes as a whole........then you can remove the vinyl covered pad .
I want to swap just the pad over to my 98 hatch, because mine has blemishes. The pad is just the part that you see when it is installed, the actual dash is a metal frame that the pad bolts onto.
sorry for the mass confusion, I didnt think pad would be that hard to figure out, since it is a vinyl covered <U>padded</U> plastic.
Old Feb 7, 2003 | 07:46 AM
fire7882's Avatar
I don't think the pad can be replaced. I tried to pull the pad off of a 95 dash and there was no way to replace it. I ended up getting a new dash from the junk yard.
Old Feb 7, 2003 | 09:21 AM
4g4me's Avatar
Default Re: 96-98 and 99-00 dash compatibility.... (fire7882)
hmm., 5th gen......thanks alot
Uljima
Nov 22, 2016 07:48 PM
import-tooner
Apr 5, 2009 07:36 PM
ThE BiG RauL
Oct 29, 2008 12:30 PM
STPREZ
Mar 15, 2006 07:22 PM
DannyITR
Nov 12, 2004 09:58 AM
