vtec engagement not right
Old Feb 3, 2003 | 10:39 AM
dpo95si's Avatar
Default vtec engagement not right
I've got a 95 gsr w/ K&N air intake, 00 type r lower exhaust manifold, straight pipe in place of cat, and a Thermal cat back exhaust off the same 00 type r the manifold came from.
My problem is some times the vtec seems to kick in kinda soft at 4500rpm and then hit home at the usual 57-5800rpm. but some times it won't kick in at all.
What could be causing this? is there any way to check the solenoid? could fuel pressure be an issue. I had a 95 delsol w/ a b16 and it was loud and proud when it hit vtec but this car is just kinda soft and the power boost isn't there.
Old Feb 3, 2003 | 10:58 AM
conesmasher's Avatar
Default Re: vtec engagement not right (dpo95si)
I think that you are confusing the dual-stage intake manifold with v-tec engagement. GSR's have a dual-stage intake manifold that kicks in about 4000rpm-4500rpm, and then vtec hits about 6krpm. this helps out tourque curves and also gives the highly known two dips in the power band of a GSR as shown on by most dyno graphs. These things have alot of factors as far as how it sounds, too many to name.
But if you think that you are having a problem with VTEC engagment make sure that you check out oil pressure first.
Old Feb 3, 2003 | 10:59 AM
NeoGSR's Avatar
vtec=4,400
secondaries=5,700
vtec needs at least 50psi of oil pressure and at correct operating tempature...there is a way to test the solenoid, try a search on this topic and you'll find alot more info...i've seen some good topics on this in the past
Old Feb 3, 2003 | 11:00 AM
NeoGSR's Avatar
Default Re: vtec engagement not right (snoballgsr)
totally ***-backwards man
Old Feb 3, 2003 | 11:08 AM
Default Re: vtec engagement not right (NeoGSR)
I won't bash you but I am about 99% sure I am right.
Old Feb 3, 2003 | 11:15 AM
PoW3l2BaN's Avatar
sorry snoball, but you do have it totally backwards...the gsr hits vtec at 4400 and secondaries open around 5700...the itr and si's hit vtec at 5500ish because they are single stage..
Old Feb 3, 2003 | 01:54 PM
TEGME's Avatar
Default Re: vtec engagement not right (PoW3l2BaN)
vtec @ 4400
Secondary @ 5600~5700
I have the same car and nearly same setup as you.
Test your ECU, i can almost guarantee you are throwing a #22 CEL
check out http://www.c-speedracing.com on how to test your ECU and for what the codes mean.
I havent fixed mine yet, if you find a fix pleae direct me to it. thanks.
Old Feb 3, 2003 | 02:11 PM
acatak's Avatar
Default Re: vtec engagement not right (Jiz101)
newbs
Old Feb 3, 2003 | 04:50 PM
-iLLuZioN-B18C1's Avatar
That was funny! LOL
That was even funnier!
Old Feb 3, 2003 | 05:11 PM
MachAF's Avatar
If VTEC is not enguaging I would check your oil level, make sure your not low.
VTEC is not a sudden increase it power, it just continues making power at the higher rpms, you shouldn't feel anything. If you do feel a sudden change in power then you have your engaugment set wrong.
Old Feb 3, 2003 | 05:14 PM
B2FiNiTY's Avatar
Check you oil
Old Feb 3, 2003 | 05:54 PM
dpo95si's Avatar
Default Re: vtec engagement not right (B2FiNiTY)
my oil level is correct, i check it way too often. What are secondaries? I have never heard of secondaries on a gsr. I realize the intake is designed differently than a si or type r.And you guys are tellin' me the vtec kicks in at 4500 or 5700 rpm? you can deffinitly hear and feel a differance at 4500 but its not anything to brag about, but at 5700 rpm it lets you know something happened (when and if it engages)
thanks for the replys
Old Feb 3, 2003 | 08:54 PM
I know about both of these things. Both the Prelude SH and the GSR have dual-stage intake manifolds, so I as now stand corrected, when VTEC kicks in at 4500rpm or so it feels kinda like a limp dick, but I know what you mean when it hits 6grand and you feel like your turbo finally spooled up(just for dramatization, please don't take that comment to it's potential). I have the same thing in my GSR, I think IMO that it mainly to keep a good streetable feel unlike the type R and the Civic Si which feels like nothing until Six grand.
Sorry to everyone who has corrected me I guess I was just wrong.
Old Feb 3, 2003 | 09:07 PM
beaterman's Avatar
man just change your oil or add some oil. my friends prelude did the same thing and he just added oil.
Old Feb 3, 2003 | 09:11 PM
jeebusm3's Avatar
Default Re: vtec engagement not right (beaterman)
The GSR has VTEC come in, then the secondaries later. The power is more linear than a b16 or b18c5. You won't necessarily feel or hear it as much because of this, but the power is there...and more predictable.
Old Feb 4, 2003 | 12:18 AM
R-gonaut's Avatar
Check your oil
best advice right there...
[Modified by gsrmunj, 1:20 AM 2/4/2003]
Old Feb 4, 2003 | 06:06 AM
dpo95si's Avatar
i check the oil every morning before starting the car. car dosn't use a drop of oil in a 3000mile oil change cycle. so i know the oil level is good
Old Feb 4, 2003 | 07:15 AM
NeoGSR's Avatar
just get your facts straight before you make it sound like you know something...do a search, you'll find good info!
Old Feb 4, 2003 | 07:28 AM
jeebusm3's Avatar
why the hell would you check your oil every morning? That's going overboard, especially since you say it doesn't use a drop of oil.
Old Feb 4, 2003 | 01:02 PM
dpo95si's Avatar
Default Re: vtec engagement not right (gtravsr)
because i have only had the car a little over 2 months and am trying to see if it uses any oil. i have driven it 6300 miles in that time frame. 2 oil changes.
RopethisS2K
Mar 5, 2006 05:57 AM
95dhocinteg
Oct 7, 2005 05:34 PM
GsRwHiTe
Feb 15, 2004 03:01 PM
vietshinobi
Oct 14, 2002 08:45 AM
ITR1071
Sep 19, 2002 12:29 PM
