ok CTR cam in a '98 spec
Old Feb 2, 2003 | 09:33 PM
98cwitr's Avatar
Default ok CTR cam in a '98 spec
search sucked on this one...am i going to notice a big difference in the VTEC switch if I intall a CTR intake cam in my '98 R?
Old Feb 2, 2003 | 10:01 PM
skafia's Avatar
25 Year Member
Default Re: ok CTR cam in a '98 spec (98cwitr)
I doubt it. For the money, it wouldn't be worth it...
Old Feb 2, 2003 | 10:33 PM
Nameless RB26's Avatar
Would you be doing such a mod just for the vtec sound? If so, you should probably shoot yourself. Otherwise.. I don't think it will be much of a power gain. Close to nothing is my guess...
Old Feb 2, 2003 | 11:05 PM
JDM CTR '00's Avatar
Default Re: ok CTR cam in a '98 spec (Nameless)
lol
Old Feb 3, 2003 | 12:16 AM
B2FiNiTY's Avatar
A difference but not a big difference.
Old Feb 3, 2003 | 03:32 AM
kenji's Avatar
25 Year Member
Default Re: ok CTR cam in a '98 spec (B2FiNiTY)
A few years back I did a dyno comparing the '97-'98 USDM ITR intake cam to the CTR intake cam. I had the same ITR exhaust cam for all the runs. I wish I still had that dyno graph laying around.
Power and torque before VTEC was identical. This is intuitive, since the primary and secondary lobes are identical. However, after VTEC I gained 2-5 Hp throughout. So, the extra duration (3 degrees) does make a difference. Is it worth it? That is up to you...
-kenji
Old Feb 3, 2003 | 04:21 AM
Asahi's Avatar
Default Re: ok CTR cam in a '98 spec (kenji)
-kenji
I had very similar gains using a 2000/2001 ITR Intake Cam.
Figure some Rice kid will pay $200 for your 98 cam cause it is from a Type-R and you can end up paying about $90 for the whole upgrade.
Old Feb 3, 2003 | 04:56 AM
Mr Furball's Avatar
Default Re: ok CTR cam in a '98 spec (Asahi)
2000 intake cam is same as ctr cam. The only difference is you will be paing more for CTR cam because it says CTR. Save the funds and get a 2000 cam.
Same end result
Old Feb 3, 2003 | 08:25 AM
GokuSSJ4's Avatar
Default Re: ok CTR cam in a '98 spec (FURBALL B-16)
01 itr and ctr have one degree difference ,very minimal but there not exact the same ..
Old Feb 3, 2003 | 09:06 AM
Mr Furball's Avatar
Default Re: ok CTR cam in a '98 spec (Spoon1)
BusteD
[Modified by FURBALL B-16, 1:07 PM 2/3/2003]
Old Feb 3, 2003 | 09:11 AM
Asahi's Avatar
I don't disagree the ITR and CTR cams are slightly differnet but find it funny people say there is no worthwhile difference between a 98 and 00/01 ITR Intake cam but are quick to point out there is some minimal difference between a CTR and ITR cam.
That said you will see a bigger gain from a 98 to 2000 ITR cam than from a 2000 to CTR cam. (All cams mentioned are intake cams)
Old Feb 3, 2003 | 09:23 AM
jdmjunky's Avatar
wouldn't it be better off just installing some stage I skunks..
Old Feb 3, 2003 | 09:28 AM
Hooch'n's Avatar
Default Re: ok CTR cam in a '98 spec (jdmjunky)
yep, going with a new cam set-up would yelled more power.
Old Feb 3, 2003 | 10:40 AM
Ex-ITR5874's Avatar
Default Re: ok CTR cam in a '98 spec (Hooch at 8400-RPM)
Toda A would be it for me... Something the stock valvetrain can handle. But nothing up to 9500 or something that require Ti parts... I blew my b18c6 though parts were installed properly. It lasted 40.000km and bang!
Rene M
Feb 6, 2008 04:18 PM
xkhalil333x
Sep 12, 2003 07:53 PM
98cwitr
Nov 17, 2002 05:47 AM
speeddave
May 3, 2002 10:32 AM
CheezeFrog
Sep 1, 2001 06:42 PM
