Quick lowering/alignment question
I know it's probably been asked a bunch of times, but I'm ill-informed and searching just gave me contrary answers and couldn't find anything really useful. I'm about to install some Neuspeed sport springs (1.5-1.75" drop, as far as I know) - am I going to need a camber kit if I want to keep wear to a minimum? I know I should have the alignment checked as a matter of procedure, just wondering if the extra step is needed. Does the fact that I'm still using stock wheels matter at all? Thanks
ull get some neg. camber but if ur within 1 percent u should be OK..usually a camber kit is recomend d for drops exceeding 1 3/4" s..a small amount of neg. camber is good for performance
i heard that a pretty safe drop is about 1.5" at the most, and an alignment would be able to correct the camber without a camber kit. but for more serious drops, i would suggest the use of a camber kit.
What you need to worry about is toe. Have your toe set back to 0 after lowering. Also, you can do the washer trick for the rear to reduce the camber. Remember, a Civic is -1 in the rear from the factory, so running a little negative camber is OK. Run that for awhile and rotate your tires regularly. If you start to notice any uneven wear then buy a front camber kit. Hope this helps.
