Clutch Cable Adjustment
Old Feb 2, 2003 | 09:46 AM
Kato7997's Avatar
Default Clutch Cable Adjustment
How do you adjust the cluth cable on an 89 HB?? Do you do it from underneath the car?? On which part is th adjustment made??
Old Feb 2, 2003 | 09:51 AM
Flexmyrex's Avatar
Default Re: Clutch Cable Adjustment (Kato7997)
the adjustment is done by twisting the black piece, its located on the cable tranny bracket right under your battery
Old Feb 2, 2003 | 01:06 PM
bryant's Avatar
Default Re: Clutch Cable Adjustment (flexmyREX)
yep, just mess with that and see where you like it.
Old Feb 2, 2003 | 01:07 PM
Urban Business
Guest
Posts: n/a
Default Re: Clutch Cable Adjustment (Bryant)
prolly easier to pull the batery out, i always destroy my hands on it otherwise
Old Feb 2, 2003 | 03:02 PM
Custom Rex's Avatar
Adjusting the clutch cable, is this affect the life of your clutch in any way? like is it a adjustment or tension? cause tension would make it wear out faster??right?
Old Feb 2, 2003 | 05:20 PM
keebler65's Avatar
Default Re: Clutch Cable Adjustment (Custom Rex)
it basically adjusts where the pedal is in the movement of the clutch. the actual tension would be the pressure plate. but if your alignment is off enough, you wont even be able to get into gear. so its not really a matter of fine tuning - its more it either works or it doesnt.
as for the proper instructions, follow your helms for the proper steps. some aftermarket clutches require a difference procedure, in which case you should follow their instructions. every setup is different. removing the battery as stated above is a big help. it should take more than 10 mins to adjust it.
Old Feb 3, 2003 | 04:39 PM
jdlvl_type_R's Avatar
you just gotta adjusted it and play with it to see where you like it to grab. some people like to have play on it ...or some like it to grab at the top, so just mess around with it..
Radim
Feb 19, 2010 11:15 AM
BLKHB89
Apr 12, 2008 08:17 AM
andrey320
18
Jan 21, 2008 06:22 AM
ThaMatrix
Jun 7, 2005 03:15 PM
Slvr_CRX
Dec 13, 2004 10:08 AM
