Rear Brake swap....?
I know I know, I searched
I am doing a rear brake swap, I read that there is one bolt I am not suppose to touch or unbolt. That is the bolt for the toe or something, I don't want to screw up my alignment. So which one is it??
thanks
thanks
the bolt that holds the front compensator arm in place. the job will go much easier if you just loosen it. Do things right and go get an alignment afterwards.
btw, i tried the same thing when i did my rear disc comversion. one rear was in spec while the other was off. just go ahead and plan on an alignment.
qat727
Dec 14, 2006 07:59 PM
johnny hatchback
11
Mar 31, 2003 07:11 AM
